Re: ADVANCING CAM TIMING 2-4*
[Re: Labratt]
#814495
09/26/10 10:57 AM
09/26/10 10:57 AM
Posts: 17,884 S.E. Michigan
ZIPPY
S.E. Michigan
Randy what was the 1/4 et/mph when it went 1.52?
Rich H.
Esse Quam Videri
[Re: 440Jim]
#814502
09/26/10 03:33 PM
09/26/10 03:33 PM
Posts: 3,695 nc
emarine01
nc
IMO, 10.2 CR isn't enough for a 262/266 cam; so you are giving up some in that area. You can try the cam installed position, it is time and labor not money. Having the heads done by MCH will definitely make a big improvement and mill them for smaller chambers, more CR, while they are out.
3740 lbs is a lot of weight to move, so you are doing OK.
We camed down 18 degrees with 12 to 1 from 280@.050 to 262 a hair small in duration and found major torque gains
[Re: Labratt]
#814503
09/26/10 03:39 PM
09/26/10 03:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Randy I would advance it... might try it at 100 to 102 to pick up some torque which will bring the stall up some on the converter... but advancing it will cut some of the high rpm's
[Re: Labratt]
#814505
09/26/10 06:37 PM
09/26/10 06:37 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I had my edelbrocks milled .050 and used copper coated steel shims to get mine up to 11.1, quench was right at .040.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Labratt]
#814507
09/26/10 08:39 PM
09/26/10 08:39 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
First off, I think your combos running really good. If you do nothing to your heads I would try advancing it 4* to around 101* ICL. That is if ?? your P/V clearence will allow that. I wouldnt waste my time with just 2* o you still have time to do this yet this season, If so I would try it If not, and your really considering doing the heads. I agree about having Modern cnc port them and give them about a .050 shave to bump up your comp. to about 10.75 or so. To get to 12.1 you will need 0 deck pistons and a .070 shave. I wouldnt bother IMO, Id keep it 11.1 max with that cam so you could still run pump gas if you need to. E85, I wouldnt touch it. That stuff sucks I hear. mike PS, I PM,ed. you back but your mail box was full, about Norwalk!
[Re: Labratt]
#814508
09/26/10 09:09 PM
09/26/10 09:09 PM
Posts: 10 Saskatoon, Canada
sk68gtx
Saskatoon, Canada
You might want to check where it is at now, depending on the number of passes and how much RPM it has seen the chain might have a few degrees of stretch in it? Bob P.
68 GTX 440-6
10.92 @ 120
03 CTD Laramie QC 4x4
[Re: Labratt]
#814511
09/27/10 10:11 AM
09/27/10 10:11 AM
Posts: 4,074 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
... What is the consensus? Thanks for your opinions in advance!
Someone or maybe many have said to up the compression via milling some off during the refresh . Nothing wrong with 11.5 to 1 or slightly less CR IMO (with good quench!!!). That'll bring that cam and its current position into optimum(wording make sense? )LOL. I don't know if moving it from its current position would help a bunch...did you measure current cranking compression?
