Sure Grip Question #814166
09/25/10 07:38 PM
09/25/10 07:38 PM
middle of the country
aar1 Offline OP
aar1  Offline OP
My cuda (slap stick) has an 8 3/4 sure grip rear end. I did a little power breaking the other day and noticed only the right rear tire would spin. In the past, both tires spun as they should. If I put the car up in the air, start it, put it in drive (or reverse), both tires spin in the same direction. If I have the car in neutral and I spin the tires by hand, they both spin as they should. I have no idea how old the fluid is in the rear end, but it is not low. Thoughts??
Re: Sure Grip Question [Re: aar1] #814167
09/25/10 08:20 PM
09/25/10 08:20 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
sounds like the clutches/cone might be in the early stages of being worn out.
Re: Sure Grip Question [Re: aar1] #814168
09/26/10 11:47 AM
09/26/10 11:47 AM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I had the same problem...
What I did is,
If it's a Clutch Type.
Change your Diff. oil and do not add Sure Grip Additive yet,
Go for a road test,
If both tires spin add 1 ounce of additive at the time to eliminate chatter (too much additive cause slip).
This recipe work for me
If you have no change your clutch are worn out.
If it's Cone Type.
You can try it but I never did it myself
Re: Sure Grip Question [Re: STROKIE] #814169
09/26/10 02:47 PM
09/26/10 02:47 PM
aar1 Offline OP
aar1  Offline OP
Just to show my stupidity............ how do I know if it's a clutch or cone type? All I know is it's an 8 3/4, 355 gear sure grip.
Re: Sure Grip Question [Re: aar1] #814170
09/26/10 04:59 PM
09/26/10 04:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If it is the original rear to the car it WILL be a uke CONE type , but there is no way of knowing without looking.
If you do a brake stand and only one spins it's pretty much worn out , do your self a huge favor and don't put another one of those pieces of junk back in there .
