03 neon sunroof not working need help #81384
06/29/08 12:17 AM
06/29/08 12:17 AM
md
mopars4ever Offline OP
md
My daughters 03 neon sunroof stopped working. Can someone give me a idea what to check for? Thanks, Mike
Re: 03 neon sunroof not working need help [Re: mopars4ever] #81385
06/29/08 12:29 AM
06/29/08 12:29 AM
Rohnert Park, Ca
ryan053 Offline
ryan053  Offline
Rohnert Park, Ca
did you check the fuse?
Re: 03 neon sunroof not working need help [Re: ryan053] #81386
06/29/08 01:01 AM
06/29/08 01:01 AM
md
md
getting juice , ran slow for a few days, now no worky
Re: 03 neon sunroof not working need help [Re: mopars4ever] #81387
06/29/08 03:42 AM
06/29/08 03:42 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
You'll need a new track/motor assy..... And after you install it disable the switch so that it never opens again. That is the only way it will not happen again.
Re: 03 neon sunroof not working need help [Re: J_BODY] #81388
06/29/08 09:22 AM
06/29/08 09:22 AM
md
md
common problem I assume?
Re: 03 neon sunroof not working need help [Re: mopars4ever] #81389
06/29/08 10:40 AM
06/29/08 10:40 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
done my share.
Re: 03 neon sunroof not working need help [Re: J_BODY] #81390
06/29/08 10:46 AM
06/29/08 10:46 AM
md
md
Is it hard to get to? How hard is it to get the headliner out? Mike
Re: 03 neon sunroof not working need help [Re: mopars4ever] #81391
06/29/08 07:57 PM
06/29/08 07:57 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Lay the seats back, grab your cordless screw driver and get to work. They come out pretty easy. Drop it, turn it, comes out the door. From there you can see first hand what's wrong. Can't remember ever "repairing" one, but most the track assy gets replaced. Funny thing is I ordered a sunroof assy for a Saturn one time and it looked just like the Neon one.
Re: 03 neon sunroof not working need help [Re: J_BODY] #81392
06/29/08 09:30 PM
06/29/08 09:30 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I chewed up the motor drive gear on mine.
Replaced it and then the track assembly went out 2 months later.
Just get it closed and never open it again.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 03 neon sunroof not working need help [Re: wingman] #81393
06/29/08 09:41 PM
06/29/08 09:41 PM
md
md
I think it is the tracks because we were hearing a loud rattle in the roof for the past few weeks. Mike
Re: 03 neon sunroof not working need help [Re: mopars4ever] #81394
06/29/08 10:06 PM
06/29/08 10:06 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Not necessarily. The rattle you hear could just be the sliding headliner-covered "inner door" disengaaged from its tracks and rattling. This door rides in a seperate track (and is a seperate headache) from the sunroof glass.
Once you get the headliner out, pull the motor first but leave the power and test it. Also check the drive gear. If it's not the motor, then it's the tracks.
Re: 03 neon sunroof not working need help [Re: wingman] #81395
06/30/08 09:14 AM
06/30/08 09:14 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You might want to ask around over on www.srtforums.com because a lot of guys over there fix their own sun roofs.
