Trans Mount Question
#813790
09/25/10 10:27 AM
09/25/10 10:27 AM
Posts: 2,072 Cambridge, Ontario, Canada
CUDAJAS
My FSM (74 cuda) shows a spacer for the trans mount. I assume that the spacer goes between the trans and the mount. Will the lack of this spacer mess up the drive line angles, causing an RPM driven vibration? Thanks, Jason
Re: Trans Mount Question
[Re: babarracuda]
#813792
09/25/10 03:18 PM
09/25/10 03:18 PM
Posts: 1,012 indiana
mcmopars
indiana
It may cause problems. The only way to know for sure is to measure the angles at both ends of the drive shaft, or you can just put in a spacer and find out. If the lack of spacer is the problem, it will show up by the time you reach highway speed. If you notice the vibration before reaching speed, slow down and remove the spacer. Go to a drivline shop and bite the bullet.
should you stop the car or just slow down???
