Trans Mount Question #813790
09/25/10 10:27 AM
09/25/10 10:27 AM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
My FSM (74 cuda) shows a spacer for the trans mount. I assume that the spacer goes between the trans and the mount.
Will the lack of this spacer mess up the drive line angles, causing an RPM driven vibration?
Thanks,
Jason
Re: Trans Mount Question [Re: CUDAJAS] #813791
09/25/10 11:07 AM
09/25/10 11:07 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
It may cause problems. The only way to know for sure is to measure the angles at both ends of the drive shaft, or you can just put in a spacer and find out. If the lack of spacer is the problem, it will show up by the time you reach highway speed. If you notice the vibration before reaching speed, slow down and remove the spacer. Go to a drivline shop and bite the bullet.
Re: Trans Mount Question [Re: babarracuda] #813792
09/25/10 03:18 PM
09/25/10 03:18 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
should you stop the car or just slow down???
Re: Trans Mount Question [Re: mcmopars] #813793
09/25/10 06:54 PM
09/25/10 06:54 PM
scratchnfotraction Offline
most times i have removed a tranz,it had them on the bolt against the mount then tranz
I allways thought it was cause the bolts are a little to long and it keeps it from bottoming out in the tranz mount holes..which are blind and can strip/crack the tail housing
never seen them between the tranz and mount flange
74 is the spool mount correct?
Re: Trans Mount Question [Re: scratchnfotraction] #813794
09/25/10 08:10 PM
09/25/10 08:10 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The square spacer is under the bolt head on my car.
Re: Trans Mount Question [Re: mopars4ever] #813795
09/27/10 07:14 PM
09/27/10 07:14 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Well, my mistake!
I have traditional washers under the bolts.
I guess it is ok then.
Any suggestions on what would cause an RPM driven vibration? I was thinking pinion angle or trans mount issues (its new but that does not seem to mean anything these days).
Jason
