MIGHTY DEMON 750 #813477
09/24/10 08:04 PM
09/24/10 08:04 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Where can I find a rebuild kit? Are the bowl/metering block gaskets and power valve the same as holley's?
Re: MIGHTY DEMON 750 [Re: kbcuda] #813478
09/25/10 01:10 AM
09/25/10 01:10 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
AS far as I know, they are the same. Demons use a different jet design and may have more metering holes in the block, but Bowl gaskets and PV;s are the same. Demons use a larger sight plug gasket too.
