So I'm still struggling with getting a working ps pump into my 72 charger (400 B block) after it started leaking fluid badly a few weeks ago (1/2 qt a day badly). First I ordered a saginaw pump by mistake, then when the chrysler/federal one arrived it had a 0.625" press-fit shaft, while the one on the car was 0.685", and so the pulley didn't fit. I couldn't find a pulley anywhere for less than $100, so I decided to order a rebuild kit and repair the leaky pump. So I order the seal kit for the chrysler/federal pump that came with a 3rd gen charger with a 400, and it doesn't fit at all--the new reservoir seal is way too big, for starters. At least now that the pump is disassembled, I might have a better chance identifying the model number, so I can get the proper seal kit.
Does anyone recognize this pump? The number on the front reads 2129823-3, and on the reservoir side there's a pad with 'D 30' stamped on it.
Thanks in advance for any help.
Matt
