BB Gearing ? #813206
09/24/10 10:48 AM
09/24/10 10:48 AM
Southern Oregon
toyotajeep Offline OP
Southern Oregon
Hello,
I am most likely going to be putting more miles on my "hot rod" than I had initially planned. That is a good thing for me I guess
It is a 74 Dart Sport with a mild 440, SD intake, 750 or Theromquad on it, Headers, 3" exhaust. The cam is a MP .450-455. Car runs well. It has the factory HS convertor in it.
Initially, I was building a mild engine, but I built the car for a better engine in the future. It does have 4.10's in it now. It will likely see a better set of heads and maybe a slightly bigger cam but that is about it.
I need to drive a minimum of 40 miles each time I start it pretty much. Obviously 4.10's aren't going to cut it at 60-65 mph on a regular basis. At least for me they aren't. I have driven it a few miles with them and it was getting old already
I am looking at a compromise gear. Something I can get mid-teens out of for MPG, and still run 13 something at the strip.
Tire size is likely going to be 255/70/15 to match my rim size.
If you were compromising, and wanted decent driveability with a relatively mild engine, and some performance, what ratio would you run? I'd rather err on the side of conservative.
I am leaning towards 3.23's.
Also, what am I likely giving up in the quarter dropping from a 4.10 to a 3.23?
Thanks, ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: BB Gearing ? [Re: toyotajeep] #813207
09/24/10 10:53 AM
09/24/10 10:53 AM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
Try a 3.55sg. Not so stiff you can't highway travel with it.
This space available for rent
Re: BB Gearing ? [Re: toyotajeep] #813208
09/24/10 10:54 AM
09/24/10 10:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I had 3.55's in my old 340 swinger. They worked fine. I could drive about 70 no problem and got 17mpg even w/ a 750 DP.
Your 440 should run well into the 13's w/ 3.55's. That cam you have would probably like less than 4.10's So you might see an improvement. I'm guessing it quits at about 5200 and you are probably over 6 at the stripe.
Coming soon!!!!
Re: BB Gearing ? [Re: Mr.Yuck] #813209
09/24/10 11:04 AM
09/24/10 11:04 AM
Southern Oregon
Southern Oregon
You know when I built it, I started with a slightly bigger cam in another engine. I never really drove it, but once I ran the numbers, I could see the same thing. Running out of RPM wouldn't be good in the quarter!
Years ago, with a 302 F..d Mustang I ran 2.79's and then 3.55's. It was night and day with a smaller engine. It did have some real short small rear tires though so it wasn't too great going down the road though. They were probably 3-4 inches shorter though.
Re: BB Gearing ? [Re: toyotajeep] #813210
09/24/10 11:10 AM
09/24/10 11:10 AM
Kirkland, Washington
Pacnorthcuda Offline
Running out of RPM with 29" tires, 3.23 OR 3.55 and mid 13's ain't gonna happen.
Either will work. 3.23's will be more comfortable on the road and give an MPG or 2.
Re: BB Gearing ? [Re: toyotajeep] #813211
09/24/10 11:25 AM
09/24/10 11:25 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
A 255x70x15 tire it really tall, about 29" so it will help reduce your RPM at speed.
With 3.55:1 gears, 60 MPH would be about 2,500 RPM, and 70 MPH should be under 3,000 RPM (may vary a bit because of converter slippage and actual tire size.)
going from 3.55 to 3.23 is a 9% change, so your rpms would be around 250-300 RPM less.
Using a 255x60x15 tire (about 27" tall), and 3.55:1 gears, 70 MPH is about 3,150 RPM.
Re: BB Gearing ? [Re: 451Mopar] #813212
09/24/10 11:34 AM
09/24/10 11:34 AM
Southern Oregon
Southern Oregon
I meant with the 4.10's and running out.
I agree, I don't think it would be close to an issue with the 3... gears.
I guess it comes down to 3.23's vs. 3.55's.
It may be helpful to know that with the exception of a trip or two a year, all of my driving will be done on 55 MPH posted roads. Everybody drives 63-67 but I wouldn't get run off the road at 60ish.
Re: BB Gearing ? [Re: toyotajeep] #813213
09/24/10 11:44 AM
09/24/10 11:44 AM
Based on that (a 60-65 crusing speed) and 29 inch tires, I would opt for the 3.55's
Re: BB Gearing ? [Re: toyotajeep] #813214
09/24/10 12:13 PM
09/24/10 12:13 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Given what your combo is, the amount of driving and the beastly mid-range of a warmly cam'd 440.........
I'd run the 3.55's with a very tall/fat rear tire. Dart Sport/Duster boddies will accomodate 275/60-15's and bigger to go with a 28" or taller.
Short tires look bad, as in not good, on the street and the 3.55's with a 26" slick would hook well at the track.
Re: BB Gearing ? [Re: Dean_Kuzluzski] #813215
09/24/10 03:30 PM
09/24/10 03:30 PM
P
Paul_Fancsali Offline
P
I have just pulled a set of 3.55 gears out and went back to 3.91s and I street the car all the time with a similar cam in a small block. Why is everyone afraid of a engine holding 3000-3500? Don't want the buzz use 29 to 30 tall tires. I was driving the car for 2 years with 4.30s and for 8 month's 4.56 gears that was too much in Qtr the 4.30s were fine. and the 3.91s gave me great qtr mph forwhat it is, keep in mind heavy cars do need the gear. My Duster has 4.10s for over 30 years. I would drive it hunderds of miles never a problem. The 3.55s were ok but did not have the top end pull
Re: BB Gearing ? [Re: Paul_Fancsali] #813216
09/24/10 03:35 PM
09/24/10 03:35 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i'm leaning to 4.10's from my 3.55's now that i went from 25.5" tires to 28" tires on my demon. acceleration took a hit with the taller tire
Re: BB Gearing ? [Re: toyotajeep] #813217
09/24/10 04:06 PM
09/24/10 04:06 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
323's
Re: BB Gearing ? [Re: buildanother] #813218
09/24/10 04:50 PM
09/24/10 04:50 PM
IN
ahy Offline
ahy  Offline
IN
Fairly light car, lots of torque... 3.23 should work great
Re: BB Gearing ? [Re: ahy] #813219
09/24/10 10:36 PM
09/24/10 10:36 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have 3.54's and they work great
Gus
64 Plymouth Savoy
Dana 60
Re: BB Gearing ? [Re: fourgearsavoy] #813220
09/25/10 04:43 AM
09/25/10 04:43 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
another vote for 3.55
Re: BB Gearing ? [Re: fourgearsavoy] #813221
09/25/10 08:59 AM
09/25/10 08:59 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Foru Gear does yours run out of grunt on the top end.My 65 with 3.91s isnt pulling many revs in fourth.1 thru 3 is good as I shift at 6700.But once I hit 4th in the back end its loafing.Im thinking 4.30s or maybe even go back to the 4.88s.My tires are 28.5 tall.Rocky
Chrysler Firepower
Re: BB Gearing ? [Re: therocks] #813222
09/25/10 12:17 PM
09/25/10 12:17 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run 3.55 with a 28" tire and I think it sucks on the highway to have to rev 3000 needlessly. Doesn't hurt anything doing that, I just don't like it. So I decided to do an overdrive transmission so I can have the best of both.
