Re: Keith Black Hyper Pistons In a 426 Hemi
[Re: Snoopy]
#813175
09/24/10 04:43 AM
09/24/10 04:43 AM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
the 211 is higher comp than the 210, with block sqaure decked and heads cleaned up 3-5 thou you looking at more like 10.5 to1 with 38 thou gasket. which is ok for 93 and steel heads on hemi
MOPAR OR NO CAR
[Re: Snoopy]
#813180
09/25/10 06:55 AM
09/25/10 06:55 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I have had these pistons for many years and the rotating assembly has be balanced with these pistons. I would probably have to add Mallory metal to the crank if I go with forged pistons.
So if anyone has any real life experience with these pistons in a Hemi, I would like to hear from you. Pros and cons.
Hate to be anal but a good set of forged pistons aren't going to weigh any more than the 785g slugs you've already got. My custom JE's for a 4.50" bore came in at 805g without any lightening. Dave
[Re: pacifica]
#813182
09/25/10 10:41 AM
09/25/10 10:41 AM
Posts: 2,578 sweden
1Fast340
sweden
How will this motor be used? Per the chart you posted, cylinder wall clearance varies with intended use of the motor.
I used quality forged in my motor because it see's regular hard use and I agree with above post about why cut corners.
If the motor will see an easy life, then you may be ok with K/B parts.
"my motor will live an easy life" is usualy a very bad excuse wich often means noone will care about getting it tuned in just right,at some point someone will step on it and if the tune is lean or to much timing there will be broken pistons,wich may or may not ruin the block and or more.. may also happen from other fuelrelated isues. good pistons are a cheap insurance since they have a much better chance of survival
[Re: Snoopy]
#813183
09/25/10 11:08 AM
09/25/10 11:08 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Snoopy, KB Hypers are not bad pistons. Actually they are real good if you install em according to the specs.
I have a set of those on my 360 engine thats basically a stock rebuild with 10:1 compression and a little street cam.
On the other hand, on my HEMI I have Diamond Racing forged pistons.
Get my drift???
On a HEMI you dont want to cut corners on pistons....its an epensive HEMI, if something goes wrong it will be an expensive mistake and you will be banging your head against the wall. You dont want to cut corners on the shortblock.
If you put hypers on it will be something that will bug you always and will be on the back of your head everytime you want to floor that beast a little bit.
GOOD FORGED = PEACE OF MIND.
[Re: DaytonaTurbo]
#813185
09/25/10 04:51 PM
09/25/10 04:51 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Also, has a machinist checked out your block to find out if it'll cleanup for your .005 oversize pistons..?
The block has already been honed with plates to the dimensions stated in my clearance chart.
The pistons weigh 781G without pins and keepers. 947G with pins and keepers.
[Re: Snoopy]
#813186
09/25/10 05:53 PM
09/25/10 05:53 PM
domingo
EL Master
EL Master
Lima, Peru
Snoopy, like I said KBs are good....but given they are going in a HEMI I guess the price difference shouldnt hurt that much. Look for deals on building that HEMI for some less coin elsewhere really. For instance, use the stock rockers, you dont need that roller stuff.....stuff like that you can always upgrade later on....
Once you build the shortblock its there for good.
[Re: Snoopy]
#813189
09/27/10 11:11 AM
09/27/10 11:11 AM
domingo
EL Master
EL Master
Lima, Peru
Are there any member/dealers that sell Diamond or JE pistons?
Chuck at Best Machine can help you out choose a set of Diamonds. Tell him I sent you.
Like I said you will probably be fine if you go with the KBs, I have used them myself in some engines with ZERO problems. However, I would not build a hemi with them. I mean, its a HEMI. Its a race engine that somehow ended up on street cars...race engines must have forged pistons!!!
Its like having a Ferrari and putting budget Korean tires on. Yes, I guess it wont harm it and it will drive pretty much OK....but it just isnt right!!!
