02 Neon - 3rd auto trans in less than 7k miles?? #813136
09/24/10 02:11 AM
09/24/10 02:11 AM
USA
SSAAHemiFan Offline OP
USA
LOng story but maybe easy question ??
Is the fluid flow thru this trans also controlled by the body computer ?
The reason I ask is my wifes neon has just woofed it's 3rd trans in less than 7k miles.
Everytime there has been a fluid loss code that everyone has blamed on the converter.
Trans has been rebuilt 2 times by chrysler mechanic using OEM chrysler parts with the exception of the converter on the first rebuild.
Quick rundown of everything..
Original problem - Car bucks and dies, squealing noise, code shown for fluid loss - rebuild trans, flush lines and radiator, use aftermarket converter. Drive 10 miles trans comes apart on way home. Everything inside burned and rear gearset trashed.
Same code - fluid loss - Everyone think's aftermarket converter is bad - rebuild and flush everything again this time use OEM chrysler converter.
Tech drives it for 3 days with Chrysler scan tool hooked up - shifts fine , all pressure's fine.
Get about 2 blocks from his shop and observed trans temp spiking fast - pulled the lines and found return line NOT returning fluid intermittently - suspect aftermarket radiator sump restricted or plugged with clutch material from first trans coming apart.
Pull trans - check for damage - all OK - re-installed using a aftermarket cooler totally bypassed stock radiator.
Tonight wife was on her way home from work - same problem but was able to limp it home.
I am now clueless and out a bunch of cash..
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: SSAAHemiFan] #813137
09/24/10 11:53 AM
09/24/10 11:53 AM
North Central Indiana
C-Tech Offline
C-Tech  Offline
Fluid flow is NOT controlled by any computer IIRC the flow to the cooler should be the one closest to the left side of the car and fluid should flow all the time
Kevin
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: C-Tech] #813138
09/24/10 12:42 PM
09/24/10 12:42 PM
USA
USA
Thanks C-Tech - I am considering a reman trans and converter from Mopar this time since it has a warranty.
I just wanted to rule out anything computer related so I don't smoke this one also..
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: SSAAHemiFan] #813139
09/24/10 12:57 PM
09/24/10 12:57 PM
C-Tech Offline
C-Tech  Offline
The dealer doesnt warranty their rebuild?
I would think you get 12 months 12,000 miles
Kevin
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: SSAAHemiFan] #813140
09/24/10 01:36 PM
09/24/10 01:36 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I don't know the first thing about Neons but my tranny shop said to replace (not flush) the cooler lines on my Ram truck after a failure. Something about a one way valve I think, but it's been too many years and I don't remember it clearly anymore.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: C-Tech] #813141
09/24/10 02:14 PM
09/24/10 02:14 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
get a lawyer!
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: C-Tech] #813142
09/24/10 02:44 PM
09/24/10 02:44 PM
USA
USA
It was done as a side job - dealership no longer has a chrysler license - so no computer help - no parts - mechanic is retired. Was the top guy with 29 years experience.
Drove it today - no codes, fluid is topped off - little dark but not burnt.
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: 3hundred] #813143
09/24/10 02:51 PM
09/24/10 02:51 PM
C-Tech Offline
C-Tech  Offline
Robert
front wheel drives dont use the check valve like the trucks did,
Could be it was the cooler maybe you got it
Kevin
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: C-Tech] #813144
09/24/10 04:46 PM
09/24/10 04:46 PM
Warner Robins, Georgia
DusterMan Offline
super street
DusterMan  Offline
super street
have you replaced the pump??
Pete:
2003 Dodge Quad 2500 Hemi
69 RoadRunner 4 sp Alpine White
2019 Dodge Charger
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: DusterMan] #813145
09/25/10 02:28 PM
09/25/10 02:28 PM
USA
USA
yes a new mopar pump was installed after each rebuild.
First caused by broken converter and/or restricted fluid flow.
Second was the restricted return wiped out everything plus the rear planetary and sent debris thru entire trans
drove it today and can't duplicate problem again basically a real faint whine when driving and when shifting.
Wife said it was the same sound it made just before it blew the first time.
This am checked all connectors, solenoid pack for leakage, ground connection. Fluid is clean , not burnt.
Going out now to pull the pan and filter.
I'm still looking for a scan tool to buy for trans codes.
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: SSAAHemiFan] #813146
09/25/10 08:14 PM
09/25/10 08:14 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
The scan tool is almost a dealer only thing. I think that even Snap On's best will not pull the codes. I could be wrong.
ATF+4 is darker than Dexron and smells a bit burnt right from the bottle, at least to me.
I always pulse flush and then pulse backflush the lines and coolers. The fluid that I flush gets strained and if I see any crud, flush, backflush or replace. By pulsing the fluid it helps bust anything loose.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: Dave_J] #813147
09/25/10 11:25 PM
09/25/10 11:25 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Sorry to be so blunt, but it's going to fail again.
Replace it with a manual trans if at all possible and save yourself the hassle, money, and aggrivation.
You can pick up the manual trans parts cheap over at www.neons.org, and a good five speed will run you $50-$125, ready to install. You'll need a manual trans PCM, too, but those are not hard to come by either.
Having been through a four-month battle with a GM 4L60E and never winning, I swapped in a T-5 manual and no problems since. I know not everybody can and/or wants to do such a swap, by it my experience, once an auto trans is rebuilt and fails again, it's time to cut your losses.
If you're intent on keeping the auto trans, find a good used one on www.car-part.com or over at www.neons.org and swap it in. There are always people parting out cars, ans parts for these cars sell cheap...since they were cheap cars to begin with.
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: In_The_Pink] #813148
09/27/10 12:14 AM
09/27/10 12:14 AM
USA
USA
manual trans may not sound so far fetched after all..
was able to borrow a scanner - no codes.
Pulled pan and filter and strained trans fluid and definetely found more metal than I expected to see.
There was some on the magnet but quite a bit more still in suspension.
Had only been driven 2 miles since the noise was heard so maybe this time it was caught early.
I thought maybe there might have been metal left inside from the last rebuild (rear planetary basically exploded) but I don't think it would have lasted this long if that were true.
Looks like I'm going to get REAL knowledgeable about neons this week... close to a timing belt water pump change so I may just pull the motor and trans and do it all at the same time.
Re: 02 Neon - 3rd auto trans in less than 7k miles?? [Re: SSAAHemiFan] #813149
09/27/10 12:18 AM
09/27/10 12:18 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Now you're talking.
I picked up a '97 with a BHG and changed the water pump, timing belt, and belt tensioner with the engine and trans out.
Lots of help over at www.neons.org , too.
