Re: 426 hemi direct drive starter
[Re: hemi67]
#813018
09/24/10 09:36 AM
09/24/10 09:36 AM
Posts: 4,285 Ohio
64dodge572
Ohio
143T 11" flywheel/bell cause some fit problems with stock Hemi exhaust. Use the 513 bell and get another flywheel. Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: hemi67]
#813019
09/24/10 09:36 AM
09/24/10 09:36 AM
Posts: 4,799 ILL
MLR426
ILL
I have a bellhousing for 70 and later, # 2892513, and it wont fit over the 143 tooth flywheel. Is my only option with this bell to use the 130 tooth flywheel and gear reduction starter? Which bellhousing fits the 143 tooth flywheel and hemi??
thanks
513 bell is correct for 1970 and 130 tooth flywheel.
logan426
[Re: hemi67]
#813021
09/26/10 12:55 AM
09/26/10 12:55 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
The 11 inch housings will fit either starter.. I had originally tried to use the 11 in bell with the stock gear reduction starter.. It all fit well until I put the exhaust manifolds on... then... NO WAY...The starter and the manifold take the same space... Wound up using a Rob Mc starter
[Re: hemi67]
#813023
09/28/10 11:46 PM
09/28/10 11:46 PM
sthemi
Chicago Burbs
That should work, 10.5 in clutch and flywheel should use the same starter as the automatic.. I actually used that set up back in the 80s on a different car.. By the time I figured out that I had outsmarted myself by going with the 11 in bellhousing, I already had all new clutch and flywheel, so the Rob Mc starter was my best choice...
