426 hemi direct drive starter #813013
09/23/10 09:05 PM
09/23/10 09:05 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
What model years used the direct drive starter on the 426 Hemi with a 4 speed trans? Just trying to get a bellhousing and starter that will work with my 143 tooth 8 bolt flywheel. Not interested in spending a fortune on the correct bellhousing and direct drive starter for my 67 Charger.
Re: 426 hemi direct drive starter [Re: hemi67] #813014
09/23/10 09:53 PM
09/23/10 09:53 PM
Fairfield Maine
hemi4speed Offline
hemi4speed  Offline
Fairfield Maine
I went with a 440 Bell and a ROBBMC starter. Never look back!
Re: 426 hemi direct drive starter [Re: hemi67] #813015
09/24/10 12:50 AM
09/24/10 12:50 AM
Carson City, Nevada
RobbMc Offline
RobbMc  Offline
Carson City, Nevada
The original '66-'69 Hemi 4 speed cars used a 172 tooth flywheel and a direct drive starter with a special bellhousing. We have a gear reduced mini starter to replace the direct drive starter:
http://www.robbmcperformance.com/products/hemi_starter.html
However, if you are going to use the 143 tooth flywheel, you will need a bellhousing for a 143 tooth flywheel (RB or '70 and later Hemi) and a starter for a 143 tooth flywheel such as this one:
Designing a better mouse trap always seems to lead to the evolution of smarter mice. www.robbmcperformance.com
Re: 426 hemi direct drive starter [Re: RobbMc] #813016
09/24/10 06:35 AM
09/24/10 06:35 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
The engineer that designed, and the bean counter that signed off on the direct drive starter abortion for the Hemi, should have been drawn, quartered, shot, and fed to the hogs.Dave
Re: 426 hemi direct drive starter [Re: RobbMc] #813017
09/24/10 07:37 AM
09/24/10 07:37 AM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
I have a bellhousing for 70 and later, # 2892513, and it wont fit over the 143 tooth flywheel. Is my only option with this bell to use the 130 tooth flywheel and gear reduction starter? Which bellhousing fits the 143 tooth flywheel and hemi??
thanks
Re: 426 hemi direct drive starter [Re: hemi67] #813018
09/24/10 08:36 AM
09/24/10 08:36 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
143T 11" flywheel/bell cause some fit problems with stock Hemi exhaust. Use the 513 bell and get another flywheel.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 426 hemi direct drive starter [Re: hemi67] #813019
09/24/10 08:36 AM
09/24/10 08:36 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
thanks
513 bell is correct for 1970 and 130 tooth flywheel.
logan426
Re: 426 hemi direct drive starter [Re: MLR426] #813020
09/25/10 02:55 PM
09/25/10 02:55 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Thanks for your help. Apparently some of the 11 inch cast iron bells fit the direct starter and some will fit the gear reduction starter.
I will use the 513 and buy a new flywheel.
Any body need a good used 143 tooth 8 bolt flywheel that has been resurfaced??
Re: 426 hemi direct drive starter [Re: hemi67] #813021
09/25/10 11:55 PM
09/25/10 11:55 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The 11 inch housings will fit either starter..
I had originally tried to use the 11 in bell with the stock gear reduction starter..
It all fit well until I put the exhaust manifolds on... then... NO WAY...The starter and the manifold take the same space...
Wound up using a Rob Mc starter
Re: 426 hemi direct drive starter [Re: sthemi] #813022
09/28/10 08:00 PM
09/28/10 08:00 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Ouch! THanks for your help and photo. I am sticking with the 10 inch and 130 flywheel with the gear reduction starter.
Re: 426 hemi direct drive starter [Re: hemi67] #813023
09/28/10 10:46 PM
09/28/10 10:46 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
That should work, 10.5 in clutch and flywheel should use the same starter as the automatic..
I actually used that set up back in the 80s on a different car..
By the time I figured out that I had outsmarted myself by going with the 11 in bellhousing, I already had all new clutch and flywheel, so the Rob Mc starter was my best choice...
