70 B Body Air Grabber Question ? #812698
09/23/10 03:35 PM
09/23/10 03:35 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
Which is the proper Air Grabber canister for a 1970 Plymouth B Body and where exactly does it mount.
Does Engine size matter?
Sample ONE:
CHECK OUT MY NEW WEB SITE !
Re: 70 B Body Air Grabber Question ? [Re: anlauto] #812699
09/23/10 03:36 PM
09/23/10 03:36 PM
anlauto Offline OP
anlauto  Offline OP
Sample Two:
Which One ?
single choice
Votes accepted starting: 09/23/10 01:00 PM
Re: 70 B Body Air Grabber Question ? [Re: anlauto] #812700
09/23/10 03:37 PM
09/23/10 03:37 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
ENGINE SIZE DOESNT MATTER
Re: 70 B Body Air Grabber Question ? [Re: anlauto] #812701
09/23/10 04:06 PM
09/23/10 04:06 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
numero uno.
mounts low on the pass side of the firewall
Re: 70 B Body Air Grabber Question ? [Re: gtx6970] #812702
09/23/10 04:32 PM
09/23/10 04:32 PM
DELAWARE
DELAWARE
I BELIEVE THERE MAY EVEN BE 2 DIMPLE ON THE FIREWALL WHERE THE SCREWS SHOULD GO
Re: 70 B Body Air Grabber Question ? [Re: TONY_DAGOSTINO] #812703
09/23/10 05:12 PM
09/23/10 05:12 PM
okla.
O
okie Offline
okie  Offline
O
okla.
It's the first one and it mount on the passenger side firewall about a foot down on the firewall. I can measure it for you if you need it. Ronnie
Re: 70 B Body Air Grabber Question ? [Re: TONY_DAGOSTINO] #812704
09/23/10 06:00 PM
09/23/10 06:00 PM
anlauto Offline OP
anlauto  Offline OP
Firewall or inner fender....?
Pictures anyone?
Re: 70 B Body Air Grabber Question ? [Re: anlauto] #812705
09/23/10 07:42 PM
09/23/10 07:42 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Re: 70 B Body Air Grabber Question ? [Re: gtx6970] #812706
09/23/10 09:23 PM
09/23/10 09:23 PM
okla.
O
okie Offline
okie  Offline
O
okla.
It mounts on the firewall with the connections pointed toward the exzaust manifold. I don't have a way to get any pictures. Ronnie
Re: 70 B Body Air Grabber Question ? [Re: okie] #812707
09/23/10 09:37 PM
09/23/10 09:37 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Neither one. The one on the top is a std vacuum can that goes under the battery tray on 71 b-bodies it just has the one end of the bracket cut off from what I see. The correct one has a part #3441157 on the bracket. It has holes symetrically drilled at the ends of the flat bracket. I will post a pic in a minute....
Re: 70 B Body Air Grabber Question ? [Re: QuickBpBp] #812708
09/23/10 09:42 PM
09/23/10 09:42 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Here are what I am talking about the one on the top is an assist can from under the battery tray of a 71 B-body and the other is an Air grabber mounting bracket. Hope this helps. In your first pic it appears the bent part of the bracket has just been cut-off....
Re: 70 B Body Air Grabber Question ? [Re: QuickBpBp] #812709
09/23/10 10:23 PM
09/23/10 10:23 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i know i have better pics
i just can't find them
maybe these will help anyway
if you look behind the heater hoses by the firewall in this pic you will see the canister
here it is on the hood..
Re: 70 B Body Air Grabber Question ? [Re: flypaper] #812710
09/23/10 10:35 PM
09/23/10 10:35 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Re: 70 B Body Air Grabber Question ? [Re: flypaper] #812711
09/23/10 11:06 PM
09/23/10 11:06 PM
People's Republic of Kali
70runner Offline
70runner  Offline
I've sold a lot of these on ebay. It's a Trico vacuum cannister usually with a green marking on the face.
Re: 70 B Body Air Grabber Question ? [Re: 70runner] #812712
09/24/10 09:40 AM
09/24/10 09:40 AM
California
70SportSatellite Offline
super street
super street
California
IIRC the firewall is dimpled where the cannister bolts. It's just a matter of locating those and drilling them. I believe it mounts with hex head screws with a 5/16 diameter and is also slotted.
Have you decided where you are going to run the vacuum hoses. There are 2 locations used. One is next to the regulator and the other is above the heater hoses which seems to make more sense. it is rather crowded when placed by the regulator.
Re: 70 B Body Air Grabber Question ? [Re: anlauto] #812713
09/24/10 07:42 PM
09/24/10 07:42 PM
USA
b54406barrel Offline
USA
Here's some not-too-good of shots I took of a gtx that been engineless since the mid 70's. I was actually taking pics of the emission lines & PB booster, wiring, etc., for a friend but got a few of the canister in there.
Re: 70 B Body Air Grabber Question ? [Re: b54406barrel] #812714
10/10/10 05:10 PM
10/10/10 05:10 PM
Hanover, Ontario, Canada
Moparmatty Offline
Moparmatty  Offline
If you need to Alan you can come and get some measurements off of my car.
Matt Tebbutt
Ontario, Canada
Re: 70 B Body Air Grabber Question ? [Re: Moparmatty] #812715
10/10/10 09:55 PM
10/10/10 09:55 PM
anlauto Offline OP
anlauto  Offline OP
Thanks Matt...I think I'm pretty good. the car is now in getting painted
Re: 70 B Body Air Grabber Question ? [Re: anlauto] #812716
10/10/10 11:47 PM
10/10/10 11:47 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
found them
Re: 70 B Body Air Grabber Question ? [Re: flypaper] #812717
10/10/10 11:52 PM
10/10/10 11:52 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
