!!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! #812636
09/23/10 02:27 PM
09/23/10 02:27 PM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
I need some help wiring up a 2 step for a 4 speed... I heard its best to set it up off the clutch pedal..
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: NoJoke] #812637
09/23/10 02:52 PM
09/23/10 02:52 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
why not off the linelok
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: smokinwoody] #812638
09/23/10 03:50 PM
09/23/10 03:50 PM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
Im not understanding what you mean?
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: NoJoke] #812639
09/23/10 04:18 PM
09/23/10 04:18 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Look on the MSD site.
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: RobX4406] #812640
09/23/10 04:39 PM
09/23/10 04:39 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Sox and Martin Hemi Duster
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: HEMIFRED] #812641
09/23/10 04:56 PM
09/23/10 04:56 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
My 3 step is wired to the line lock. I have a 3 position (on-off-on) toggle switch on the dash to switch back and forth between the lower side and the higher limit. One for the burn-out the other for staging. The line-lock button has to be pushed in to activate the rev-limiter.
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: NoJoke] #812642
09/23/10 06:27 PM
09/23/10 06:27 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
use a relay that will switch off after the initial launch.
Dont want to activate it every time you touch clutch pedal. a couple ways to do it.
Go to umtrdragrace.com for details.
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: theclutcher] #812643
09/23/10 06:38 PM
09/23/10 06:38 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I have my 2 step wired so it can only work when the clutch pedal is pushed in, AND the line lock button is pushed in. If I release either one, it comes off the 2 step. Having it just with your line lock will not give you enough RPM in the burnout box, and it's hard to release the button consistantly with the line lock button, and be ready to pull 2nd gear right away. Also it will not stutter while using the clutch down track.
Jeff
69 GTX 68 Road Runner
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed! [Re: JERICOGTX] #812644
09/23/10 06:52 PM
09/23/10 06:52 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have mine wired to the line lock. Never had a problem with releasing it at launch or for a quick second gear change 1.5 seconds after I dump the clutch. Maybe I do but the front tires are always in the air so I don't know. I have thought about wiring some sort of a switch to the pedal but never found one that I thought that could take a beating.
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: JERICOGTX] #812645
09/23/10 06:53 PM
09/23/10 06:53 PM
Bergen County NJ
N
NoJoke Offline OP
NoJoke  Offline OP
N
Bergen County NJ
Jeff
The way you have yours set up sounds like the way to go.. I will have to get some kind or diagram to wire this up..
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: NoJoke] #812646
09/23/10 07:09 PM
09/23/10 07:09 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
I always had trouble releasing the button consistantly with it tied to lineloc.
Once talking to John Calvert, he said he has his switch mounted somewhere just in reach of finger while in first gear. I ended up welding bracket to shifter mount, put switch on it. Much easier to let off switch while closing grip rather than trying to release grip.
Worked for me.
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed! [Re: theclutcher] #812647
09/23/10 07:33 PM
09/23/10 07:33 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I run 2 switches in series with one on the clutch pedal stop and the other on the trans so the first gear lever closes it.That way the only time the 2-step is engaged is when the pedal is on the stop and the trans is in first gear.
Gus
64 Plymouth Savoy
Dana 60
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed! [Re: fourgearsavoy] #812648
09/23/10 07:57 PM
09/23/10 07:57 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I use the latching relay circuit that is shown on figure 2 of page 2 in the MSD link that Fred refers to above. With that circuit, everything works off the clutch pedal switch at launch; you don't need to release any other switch when you launch, and it does NOT activate your launch rev limiter when you jab the clutch to shift.
I set the clutch pedal switch to a point where it does not trigger untill the pedal is almost fully released. That way I can pre-stage, push in the clutch to stop in the 1st beam, hit the momentary switch to arm the latching relay, feather the clutch a little to move the car forward and stage (without tripping the clutch pedal switch and de-activating the two-step), then launch by dumping the clutch peadl, which hits the switch and deactivates the 2 step.
I don't use a line lock yet, but if I did, it would also deactivate by the same switch.
[show off] here's an in car video where you can see how slick it works, right at 1:45 where if flip the activator for the latching relay on and off then go: http://www.youtube.com/watch?v=nKfPiVjUdjU [/show off]
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: JERICOGTX] #812649
09/24/10 08:54 AM
09/24/10 08:54 AM
ohio
mike67net Offline
mopar addict
mike67net  Offline
mopar addict
ohio
Jeff
That's how I have mine. I put a "normally closed" switch at the top of the clutch pedal so it will break the circut for the 2-step and the line lock when the clutch is all the way out. Just in case I forget to let go of the button when I launch the car
I believe the switch was a Chevy brake light switch.
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: mike67net] #812650
09/24/10 10:29 AM
09/24/10 10:29 AM
Toronto
mshred Offline
mshred  Offline
Toronto
mine is setup off of my linelock button.
I have the hurst pistol grip handle with the button on top and no problems releasing it on launch. Have a toggle switch on the dash which turns the two step on and off..so, waterbox, burnout with the linelock only (that what i dont hit the two step), then stage with the toggle switch on, hold the button and sit on it till she goes green, then let go and grab em
Re: !!!!!!!!Need help wiring up a 2-Step for a 4 speed!!!!! [Re: JERICOGTX] #812651
09/26/10 11:54 AM
09/26/10 11:54 AM
Illinois
Hurst390 Offline
Hurst390  Offline
Illinois
Jeff
x2
80 AMX Barry Allen 420 AMC Iron Heads Jerico 4-speed Advanced clutch 2950# street legal 5.97 115.73 Coles county dragway 10/28/07 9.42 142.96 best in 08(6.00 115.8 1/8) 5.97 116.2 in 09 http://www.youtube.com/watch?v=AXSr201-tmA
