brake problem on my challenger, help please #812417
09/23/10 09:01 AM
09/23/10 09:01 AM
W. Bloomfield, MI
71340vert Offline OP
W. Bloomfield, MI
I have a challenger with power disc. The last time I drove it I noticed the pedal felt a little different as it seemed to have more travel to get the car to come to a stop. I then tried to slam on the brakes to see if the brakes would lock up, but they didn't, the car slowed to a stop, but not as fast as it used to. I checked the fluid in the MC and both resevoirs were full, but the front resevoir fluid was a milky tan color. I know there are no leaks. I was thinking at first the vacuum hose might have a leak, but the discolored fluid has me puzzled. Is the MC bad? How do you know or check to see if your MC isn't working?
Re: brake problem on my challenger, help please [Re: 71340vert] #812418
09/23/10 09:20 AM
09/23/10 09:20 AM
Cincinnati, Ohio
Challenger 1 Online tonguue
Challenger 1  Online Tonguue
Cincinnati, Ohio
Start by removing the fluid in the MC and refill it with fresh and procede to flush out the old fluid. It'll take 2 people just like bleeding brakes unless you have access to a pressure bleeder which would speed up the job. The milky fluid has water in it and will give you a spongy brake petal along with causing corrosion and leaks.
Re: brake problem on my challenger, help please [Re: 71340vert] #812419
09/23/10 09:34 AM
09/23/10 09:34 AM
VA
SR-71 Offline
SR-71  Offline
VA
With car on, pump brake pedal a few times and hold, if it sinks to floorboard, its probably MC. If you hear something sounding like a rush of air escaping after applying brakes coming from engine bay (as well as hard pedal pressure while applying brakes), could be PB booster. Good luck!
Re: brake problem on my challenger, help please [Re: 71340vert] #812420
09/23/10 10:40 AM
09/23/10 10:40 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Info's kinda sketchy...some more thoughts...
> Bad vac check valve
> Stuck calipers
Rick
