Ready to run- Is this OK? #81231
06/28/08 09:15 PM
06/28/08 09:15 PM
alberta
Publicbottle Offline OP
alberta
Ready to fire up my freshly built 340 in my challenger, however the clutch linkage and throwout fork are still not installed, also the driveshaft is off the car. Anybody see a problem with this?? Would i be damaging anything by doing it??
Re: Ready to run- Is this OK? [Re: Publicbottle] #81232
06/28/08 09:54 PM
06/28/08 09:54 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
You primed the enigine's oiling system first, right?
Is the trans in place?
Re: Ready to run- Is this OK? [Re: Publicbottle] #81233
06/28/08 10:08 PM
06/28/08 10:08 PM
Only thing I can think of, is that with no shaft in the car, you may lose some transmission oil out the rear. Worse if you've got the rear of the car down somewhat. Make sure there's oil in the trans, and put one of your wife's cookie sheets under there.
Re: Ready to run- Is this OK? [Re: Publicbottle] #81234
06/28/08 10:16 PM
06/28/08 10:16 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Why not wait and get it finished 1st.
I know you start getting antsey.
You have got this far, Hang in there and get it finished
Re: Ready to run- Is this OK? [Re: cyphre666] #81235
06/28/08 10:43 PM
06/28/08 10:43 PM
alberta
alberta
Ya the tranny is in, but i forgot that the oil will spill out with out the driveshaft in place. I guess i could wait, but i wont be done for a long time. Its kind of a personal stepping stone in my first restoration project, ya know...?
Re: Ready to run- Is this OK? [Re: Publicbottle] #81236
06/29/08 12:28 PM
06/29/08 12:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
IO don't think the throwout bearing would be happy flopping around in there.
