stripe placement on 70... #812019
09/22/10 07:04 PM
09/22/10 07:04 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Charger. 500 stripe. anybody have the details? I'm going to try and do it this weekend. Need to break up some of this GREEN. and do you do the sides 1st?
Coming soon!!!!
Re: stripe placement on 70... [Re: Mr.Yuck] #812020
09/24/10 10:22 AM
09/24/10 10:22 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
nobody???
Re: stripe placement on 70... [Re: Mr.Yuck] #812021
09/24/10 11:04 AM
09/24/10 11:04 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Not familiar with a 500 stripe. Do you have a photo.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: stripe placement on 70... [Re: 70gtx440dana] #812022
09/24/10 12:06 PM
09/24/10 12:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Looks like an R/T stripe only it says 500 instead.
http://fc03.deviantart.net/fs43/f/2009/100/4/7/Dodge_Charger_1970_by_AmericanMuscle.jpg
I'd do the sides first since the sidemarker lights are going to determine where the stripe ends up going. Clean the surface with wax and grease remover and then tack rag it right before the decal goes on.
Re: stripe placement on 70... [Re: Neil] #812023
09/24/10 01:18 PM
09/24/10 01:18 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
It should be like the R/T, MAKE SURE the 500 is down the center of the body line of the vehicle for up/down location and the side marker lens should be in the middle of the stripe for for/aft location. Use masking tape to locate everything and wet down the body with a little spray so you have some play in moving it around if necessary.
Re: stripe placement on 70... [Re: maximus] #812024
09/24/10 03:24 PM
09/24/10 03:24 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've read that you use a dash of dishwashing liquid & water in a squirt bottle, and then use a non-maring squeegee to work the bubbles out.They do make an actual product for applying decals that allows plenty of movemnt before they set.
As to where it goes, do a thorough Google search using the images tool.
Re: stripe placement on 70... [Re: jbc426] #812025
09/24/10 03:33 PM
09/24/10 03:33 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Soapy water works great, but don't use too much soap. A drop or two in a spray bottle is plenty. All it has to do is feel slick between your fingers in order to work right.
Personally I like applying vinyl dry when I can since it eliminates the possiblity of it sliding around. 99% of bubbles come from going too fast and/or not pressing down hard enough. I would probably do the sides dry and the trunk lid with water since it's too wide to hold onto with one hand.
Re: stripe placement on 70... [Re: Neil] #812026
09/24/10 06:25 PM
09/24/10 06:25 PM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
I laid the stripe on the car and marked it with a blue painters tape as a guide line. Sides first because of the marker lights.
Re: stripe placement on 70... [Re: Spike] #812027
09/25/10 11:16 AM
09/25/10 11:16 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks the instructions say to use the tape and some soap in the water. I'll post some pictures when it's on. I hope to give it a go tomorrow, weather permitting....
Coming soon!!!!
Re: stripe placement on 70... [Re: Mr.Yuck] #812028
09/25/10 12:06 PM
09/25/10 12:06 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I went to a "pro shop" ONCE thinking they could do it better than I can. NOT. Never again.
Re: stripe placement on 70... [Re: Commando1] #812029
09/25/10 12:22 PM
09/25/10 12:22 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
I thought the stripe with the "500" was a 69 only stripe?
Re: stripe placement on 70... [Re: badblack68] #812030
09/25/10 10:43 PM
09/25/10 10:43 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Charger 500 was a upgrade option for a 70 Charger, much like a coronet 500. It had nothing to do with the 69 500.
anyway here's my handi-work
Re: stripe placement on 70... [Re: Mr.Yuck] #812031
09/25/10 10:43 PM
09/25/10 10:43 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
next
Re: stripe placement on 70... [Re: Mr.Yuck] #812032
09/25/10 10:44 PM
09/25/10 10:44 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
last, wasn't too bad. One wrinkle but not bad for a rookie
Re: stripe placement on 70... [Re: Mr.Yuck] #812033
09/27/10 12:07 AM
09/27/10 12:07 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
They look great! Did you use soap finally?
Can you fly to Denver and help me with mine?
Craig
Re: stripe placement on 70... [Re: denfireguy] #812034
09/27/10 09:26 AM
09/27/10 09:26 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Craig
I followed the kit...5-10 drops on dish soap, cap of rubbing alcohol in a spray bottle. I had a few bubbles I poped with a smallllllll needle. I took my time lining it all up before I started pealing the tape back.
Re: stripe placement on 70... [Re: Mr.Yuck] #812035
09/27/10 09:33 AM
09/27/10 09:33 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Looks awesome, good job. I need to replace one of the stripes on the door of my 70 Challenger that got rubbed /torn. This gives me the confidence that I should be able to do it my self too.
Now you just need to get the 70 tail panel or black out your taillight surround to help break up some more of all of that green. just my opinion.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: stripe placement on 70... [Re: 6PKRTSE] #812036
09/27/10 09:41 AM
09/27/10 09:41 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Looks awesome, good job. I need to replace one of the stripes on the door of my 70 Chhalenger that got rubbed /torn. This gives me the confidence that I should be able to do it my self too.
I have the panel, and yes it NEEDS it. That is going to be a challenge because this was an XH car so I have to drill the holes and find the right mounting tabs.
Re: stripe placement on 70... [Re: Mr.Yuck] #812037
09/28/10 01:06 PM
09/28/10 01:06 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I did this once for one of my buddies Chargers. I made a template out of regular ole thin paper all taped together to get the width & pressed over all of the studs to get the location of them. Then transfered everything tracing onto some thicker template board like poster board & then taped on the car & drilled all of the holes. Worked perfectly.
Re: stripe placement on 70... [Re: 6PKRTSE] #812038
09/28/10 01:29 PM
09/28/10 01:29 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I did this once for one of my buddies Chargers. I made a template out of regular ole thin paper all taped together to get the width & pressed over all of the studs to get the location of them. Then transfered everything tracing onto some thinker template board like poster board & then taped on the car & drilled all of the holes. Worked perfectly.
well find the poster board and mail it to me...lol
