Re: stripe placement on 70...
[Re: Mr.Yuck]
#812021
09/24/10 11:04 AM
09/24/10 11:04 AM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
Not familiar with a 500 stripe. Do you have a photo.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: maximus]
#812024
09/24/10 03:24 PM
09/24/10 03:24 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I've read that you use a dash of dishwashing liquid & water in a squirt bottle, and then use a non-maring squeegee to work the bubbles out.They do make an actual product for applying decals that allows plenty of movemnt before they set.
As to where it goes, do a thorough Google search using the images tool.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Mr.Yuck]
#812028
09/25/10 12:06 PM
09/25/10 12:06 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Thanks the instructions say to use the tape and some soap in the water. I'll post some pictures when it's on. I hope to give it a go tomorrow, weather permitting....
I went to a "pro shop" ONCE thinking they could do it better than I can. NOT. Never again.
[Re: Mr.Yuck]
#812033
09/27/10 12:07 AM
09/27/10 12:07 AM
Posts: 1,822 Colorado
denfireguy
Colorado
last, wasn't too bad. One wrinkle but not bad for a rookie
They look great! Did you use soap finally? Can you fly to Denver and help me with mine? Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#812034
09/27/10 09:26 AM
09/27/10 09:26 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I followed the kit...5-10 drops on dish soap, cap of rubbing alcohol in a spray bottle. I had a few bubbles I poped with a smallllllll needle. I took my time lining it all up before I started pealing the tape back.
[Re: Mr.Yuck]
#812035
09/27/10 09:33 AM
09/27/10 09:33 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Looks awesome, good job. I need to replace one of the stripes on the door of my 70 Challenger that got rubbed /torn. This gives me the confidence that I should be able to do it my self too. Now you just need to get the 70 tail panel or black out your taillight surround to help break up some more of all of that green. just my opinion.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#812036
09/27/10 09:41 AM
09/27/10 09:41 AM
Mr.Yuck
Brookeville, Md
Looks awesome, good job. I need to replace one of the stripes on the door of my 70 Chhalenger that got rubbed /torn. This gives me the confidence that I should be able to do it my self too. Now you just need to get the 70 tail panel or black out your taillight surround to help break up some more of all of that green. just my opinion.
I have the panel, and yes it NEEDS it. That is going to be a challenge because this was an XH car so I have to drill the holes and find the right mounting tabs.
[Re: Mr.Yuck]
#812037
09/28/10 01:06 PM
09/28/10 01:06 PM
6PKRTSE
Motor City
I did this once for one of my buddies Chargers. I made a template out of regular ole thin paper all taped together to get the width & pressed over all of the studs to get the location of them. Then transfered everything tracing onto some thicker template board like poster board & then taped on the car & drilled all of the holes. Worked perfectly.
[Re: 6PKRTSE]
#812038
09/28/10 01:29 PM
09/28/10 01:29 PM
Mr.Yuck
Brookeville, Md
I did this once for one of my buddies Chargers. I made a template out of regular ole thin paper all taped together to get the width & pressed over all of the studs to get the location of them. Then transfered everything tracing onto some thinker template board like poster board & then taped on the car & drilled all of the holes. Worked perfectly.
well find the poster board and mail it to me...lol
[Re: Mr.Yuck]
#812039
09/29/10 01:25 PM
09/29/10 01:25 PM
6PKRTSE
Motor City
Sorry, it was thrown away when we were done with it a long time ago.
