Block Stamping Question(s)
#81196
06/28/08 09:00 PM
06/28/08 09:00 PM
Posts: 1,592 Mansfield, TEXAS
JOES4FORTY
Mansfield, TEXAS
I picked up a 69 cast 340 block with a casting number 2780930-340. By the number one cylinder is stamped FW340P30660111. Is the stamped number the VIN? Where else is there to look on a small block for a sequential number?? Can somebody please decode the stamping for me? THANKS MOPARTS!
The GTS Registry!MOPARTS MEMBER IN PRINT 1969 Dart GTS LS23P9B (First day of production car money pit)
Re: Block Stamping Question(s)
[Re: JOES4FORTY]
#81197
06/28/08 09:14 PM
06/28/08 09:14 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
There are two numbers, the VIN number and the engine serial number. FW340P30660111 is the engine serial number, it decodes like this;
F - Series (model year) 1970
W - Engine assembly plant, Windsor, Ontario
340 - 340 CID
P - Premium fuel reccomended
3066 - Engine final assembly date from the 10,000 day calendar - Dec. 19, 1969 (1970 model year)
0111 - 111th engine assembled at the plant above on the date above.
The VIN number will be on the passenger side of the block slightly above the oil pan rail.
[Re: Alaskan_TA]
#81198
06/28/08 10:35 PM
06/28/08 10:35 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
340 - 340 CID
I sure wish people selling 1970 casting dated 340 blocks would add the (bolded) 10,000 date to thier ads, it would sure make my hunt for the block I want easier
[Re: ScottSmith_Harms]
#81199
06/28/08 10:55 PM
06/28/08 10:55 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Scott, If it is a 1970 Hamtramck or LA car, just register and I will contact you if the block from the car surfaces. (or if I know of it already) Barry
[Re: JOES4FORTY]
#81200
06/28/08 11:11 PM
06/28/08 11:11 PM
JOES4FORTY
Mansfield, TEXAS
Thanks guys! I'll do a little scraping tomorrow and get the VIN off the side of the pan rail.
[Re: JOES4FORTY]
#81202
06/29/08 11:57 PM
06/29/08 11:57 PM
JOES4FORTY
Mansfield, TEXAS
The VIN begins with an E and has a six digit number following. Barry I shot you a email with the numbers for you to check.
[Re: JOES4FORTY]
#81203
06/30/08 12:22 AM
06/30/08 12:22 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Scott, My original engines assembly date is five days after my cars SPD, it happened. Either the engine was not available and the car was built late or the engine date has a typo. Joe, It is from a 1970 LA built car, so it has to be from a Duster, Cuda or Challenger. Barry
[Re: JOES4FORTY]
#81204
06/30/08 12:30 AM
06/30/08 12:30 AM
JOES4FORTY
Mansfield, TEXAS
Barry
The owner had passed away and his wife said he was always bringing cars home. There is no telling what kind of car the 340 was out of.
Another quick question....Where would a 340 have been assembled if it were stamped DW340? Detroit?
Thanks again guys!
[Re: JOES4FORTY]
#81205
06/30/08 12:56 AM
06/30/08 12:56 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
Barry
Thanks again guys!
First digit "D" is the model year designator 1968 2 nd W = Windsor plant
Barry laid it out above in an earlier post.
[Re: RobX4406]
#81206
06/30/08 02:28 AM
06/30/08 02:28 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, I understand, happened all the time, just trying to do a little better
