welded on reinforcement LCA plate Q
#811522
09/22/10 12:58 AM
09/22/10 12:58 AM
RapidRobert
A body. I understand it should be cut/compressed a certain amt to reduce the play then the plate welded on the bottom. How tight do I want it to be? Thank you for your time.
Re: welded on reinforcement LCA plate Q
[Re: Jim_Lusk]
#811524
09/22/10 09:30 PM
09/22/10 09:30 PM
RapidRobert
Alright Jim I will do it. Thank you.
[Re: GregCon]
#811526
09/22/10 11:23 PM
09/22/10 11:23 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
LCA plates are a waste of time.
Oh no there not, IMO! Mopars are known for front end tire wobble.
Any thing you can do to tighten , any of the front end componets, will help that issue.
If you have a small home mig welder or have a buddy that does, its a El cheapo fix in the right direction.
Is it absolutely needed, no, but it will help in the scheme of things. mike
[Re: GregCon]
#811527
09/23/10 12:05 AM
09/23/10 12:05 AM
Posts: 18,157 Mass
DAYCLONA
Mass
LCA plates are just as beneficial as boxing in a frame rail, or gusseting a rollbar, etc,....if your running them on a trailer queen,..then yes they're a waste of time,...but Robert has some "intentions" behind his build using them
[Re: GregCon]
#811530
09/23/10 01:26 AM
09/23/10 01:26 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Will a plate make an LCA stiffer and less prone to flexing? Yes, mostly in the torsional direction. Unfortunately, LCA see very little torsional force. In the direction they see force - the vertical bending plane - they are quite strong by design. ...
At the sway bar tab area there are torsional forces. Especially on the 70-74 B/E LCA and the 73-76 A body LCA. Those look like the left LCA pictured in the my post above. They don't have any support on the bottom of the LCA halves.
I added that welded in support strap under the sway bar tab in my picture above. That is not factory. I run a 1.25" front sway bar compared to a factory 7/8 sway bar. The 1.25" sway bar exerts over 3 TIMES as much force on the sway bar tab.
I wouldn't put tab under the strut rod if I had them to make again. That's where every one I've seen has bent at. But I'd rather replace a bent LCA than fix a bent frame.
