Re: weird bog on 440 after full throttle for 3 seconds
[Re: ph23vo]
#811506
09/22/10 01:12 AM
09/22/10 01:12 AM
RapidRobert
Might hook a can of gas set in the eng compartment to the pump inlet & if then all good that'd elim the pump/pump line to carb as being inadequate & let you work on the rear line/sending unit. EDIT make sure your filter flows enough
