Brake bleeding problems on a low mount master cylinder #810529
09/21/10 04:51 PM
09/21/10 04:51 PM
Shingle Springs Ca
haddixj Offline OP
haddixj  Offline OP
Shingle Springs Ca
I have bleed this thing alot and still can't get a good pedal for the first pump. After it's pumped up it's good I have residual valves and 4 corner strange disc brakes. It will pump up after one pump. I also have a strange master cylinder and all the fittings are tight and leak free. Is there some magic vacuum bleared for bleeding these things when the calipers are higher then the master?
Thanks for help jason
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: Brake bleeding problems on a low mount master cylinder [Re: haddixj] #810530
09/21/10 05:23 PM
09/21/10 05:23 PM
Az
Crizila Offline
Crizila  Offline
Az
Depending on how much lower the master is than the calipers, you can jack up the front of the car until the master is above the rear calipers and gravity bleed them. Same with the fronts if you can get the car high enough. Have you got free play between the master cup and the push rod so fluid is returning to the master resivoir? Also, assume you bled the master first?
Fastest 300
Re: Brake bleeding problems on a low mount master cylinder [Re: haddixj] #810531
09/21/10 05:23 PM
09/21/10 05:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
See if you can find someone(older gas station) that
has a power bleeder... works under pressure
Re: Brake bleeding problems on a low mount master cylinder [Re: haddixj] #810532
09/21/10 06:24 PM
09/21/10 06:24 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
that's common with your set up. I learned to live with mine
home of the
Sox and Martin Hemi Duster
Re: Brake bleeding problems on a low mount master cylinder [Re: HEMIFRED] #810533
09/21/10 06:30 PM
09/21/10 06:30 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
i un bolt the cailpers and let them hang down to bleed in that case.
i have a peice of 3/8 steel cut that i put in the cailper to act as the rotor so the pistons dont over travel
works good for me, give it a try.
and yes as stated above, make sure the master cylinder is bench bleeded or you will never get a good pedal
Bob
Re: Brake bleeding problems on a low mount master cylinder [Re: BobsProFab] #810534
09/21/10 11:52 PM
09/21/10 11:52 PM
sg66mopar Offline
sg66mopar  Offline
Do you have nice flat - parallel rotors and new pads that aren't worn on a taper? That makes all the difference. If the pads are tapered they will want to push the pistons back into the bores when you let off the pedal.
If all that is OK, I raise my car one end at a time so the master cylinder is WAY above the end I'm bleeding, then let it sit overnight before I bleed that end.
Re: Brake bleeding problems on a low mount master cylinder [Re: sg66mopar] #810535
09/22/10 12:08 AM
09/22/10 12:08 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
sorry fellows but you cannot always bleed out the problem. when the master is lower than the caliper
fluid is displaced to a degree by wear of pads and rotor. In bleeding somewhere in the system is void of fluid unless it's pressurized at all times. once the pedal is lifted there is movement in the master or caliper and that's what he feels. even a residual valve that is supposed to maintain a small amount of pressure beyond it does not alway keep out all of the slack. I'll bet half of you don't realize how your pedal is right now and differences form when you put the system together
home of the
