Re: Tranz brake ?
[Re: 512 VALIANT]
#810490
09/21/10 04:06 PM
09/21/10 04:06 PM
Posts: 13,384 Marion, South Carolina [><]
an8sec70cuda
For some transbrakes that's normal, for some it isn't. My T/A pro brake does not need the button pressed for reverse.
Re: Tranz brake ?
[Re: an8sec70cuda]
#810491
09/21/10 04:52 PM
09/21/10 04:52 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Go to MSDIGNITION.COM I think you will find a simple diagram there. The two step rev limiter activate wire will hook directly to the positive side of your transbrake. When activated it tells the two step to select it's second rev limiter. The low side.
