Page 3 of 4 1 2 3 4
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810445
03/19/11 03:08 PM
03/19/11 03:08 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Another view
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810446
03/19/11 03:09 PM
03/19/11 03:09 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Yet another
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810447
03/20/11 09:01 AM
03/20/11 09:01 AM
Minnesota
peabodyracing Offline
Minnesota
Way to go Larry!! Looking very good. I can imagine how anxious you are to turn the key on it for the 1st time. Keep up the great work. I'm so glad the car went to such a good home!
Larry
Re: Found a Home for my 512-(Coronet 440) [Re: peabodyracing] #810448
03/20/11 12:12 PM
03/20/11 12:12 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Hello Larry; hopefully I will have the transmission, torque converter and headers in by the end of the week. Then it will be the little things to take care of before it comes to life. It was such a solid car to begin with and the dents on the right side will probably be there for a while as I plan on enjoying it for a while......
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810449
03/31/11 07:34 PM
03/31/11 07:34 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Well, I pulled the engine back out and assembled the torque converter, engine and tranny. Installed as a unit; next was the headers so I dropped the pitman arm.idler arm and drag link and raised the engine up a few inches as the Doug's instructions stated. Passenger side went it easy but on the driver's side you have to partially install the headers, then install the starter before proceeding. The mini stater batt post hit the block so I had to shorten the post and install an adapter upside down so the battery cable/post would clear the block. I have a World/MP block so the water jackets protrude more than the standard mopar block. Anyway after inventing a few new swear words and a bunch of bruises the d/s header was installed. I had to make a .200" square shim to raise the d/s motor mount in order to have a little clearance between the header and the power steering unit. Surprising the column shift linkage and kickdown linkage from the 318 fit perfectly with the 512. Here are a few pix.
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810450
03/31/11 07:36 PM
03/31/11 07:36 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Driver's side
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810451
03/31/11 07:37 PM
03/31/11 07:37 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Linkage
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810452
04/01/11 09:37 AM
04/01/11 09:37 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Why did you pull the motor to install the trans?
Also if you had the motor out,header install would
have been easy, just lay them in place as you are lowering the engine in.
Very nice looking car and motor.
Re: Found a Home for my 512-(Coronet 440) [Re: demon440] #810453
04/01/11 11:38 AM
04/01/11 11:38 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
It was a lot easier to install everything as unit as I was doing it alone. If I had my 2 grandkids helping like in the past it would've been a lot easier.
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810454
04/16/11 05:52 PM
04/16/11 05:52 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Everything except exhaust pipes and driveshaft hooked up. Sounds good with 2" Doug's open headers. Should have the driveshaft by next week and possibly take it out on a maiden run. Here are a few pix
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810455
04/16/11 05:53 PM
04/16/11 05:53 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Had to use a top breather low profile air cleaner so the hood would close. I might put a SS type hood scoop on it down the road.
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810456
04/16/11 05:57 PM
04/16/11 05:57 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
I went with an MSD pro billet dist in order to clear the INDY EZ heads and an MSD Streetfire box and wires.
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810457
04/16/11 05:59 PM
04/16/11 05:59 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Another pix of the engine bay
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810458
04/16/11 06:01 PM
04/16/11 06:01 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Last pix for now; will post more of the underneath once the driveshat is hooked up.
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810459
04/16/11 06:41 PM
04/16/11 06:41 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Beautiful car and awesome project.
Old, tired, and sometimes broke down. Me, not my car...
Re: Found a Home for my 512-(Coronet 440) [Re: Shoozy] #810460
05/14/11 06:32 PM
05/14/11 06:32 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Well I am almost finished with the Coronet; just have to get the exhaust welded, install the rear bumper and get an alignment check. I will fix the dents on the passenger side after I enjoy the ride for a while first.
Re: Found a Home for my 512-(Coronet 440) [Re: Shoozy] #810461
05/14/11 06:35 PM
05/14/11 06:35 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Another pix
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810462
05/14/11 06:43 PM
05/14/11 06:43 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Front view
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810463
05/14/11 06:46 PM
05/14/11 06:46 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
And the engine bay
Re: Found a Home for my 512-(Coronet 440) [Re: Hemi_Ram] #810464
05/14/11 11:11 PM
05/14/11 11:11 PM
The car looks fantastic. I hope you really enjoy it.
Page 3 of 4 1 2 3 4
