Page 1 of 3 1 2 3
5.9 magnum hates mods? #809912
09/21/10 01:37 AM
09/21/10 01:37 AM
Bellville, Texas
U
Ultanium Offline OP
Ultanium  Offline OP
U
Bellville, Texas
I have been building a dak much like the scat Dak project in Mopar Action. I started with a '95 truck with a 5.2, dropped in a '94 5.9 & Mopar computer, & drove the tires off it. Got a few bucks saved up, added a comp cams 262 roller (260/262 .480/512), new lifters, double roller chain (0°), m1, EQ heads (2.02), all new sensors, large manifolds like Ehrenberg used, stock injectors & TB. We fired it up today, & no matter what we did, it was a dog. It idles rough, dies often, & I feel like I wasted my time & money. EGR seems fine, playing with the timing made it a little better, but harder to start. Any ideas on why this thing doesn't even bark the tires? Appreciate any advice!!
Tom in Texas
Re: 5.9 magnum hates mods? [Re: Ultanium] #809913
09/21/10 01:45 AM
09/21/10 01:45 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Could be running lean with the better flowing heads and new cam. May need to either up your fuel pressure a bit or step up injector size. Ideally you would have your computer recalibrated but I don't know if anyone offers that for those trucks.
Re: 5.9 magnum hates mods? [Re: DaytonaTurbo] #809914
09/21/10 08:10 AM
09/21/10 08:10 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'll guess your stock injectors aren't able to keep up. When you do that much modification the computer might need a upgrade. I'd swap the injectors out 1st. What did the magazine build use?
Coming soon!!!!
Re: 5.9 magnum hates mods? [Re: Mr.Yuck] #809915
09/21/10 08:17 AM
09/21/10 08:17 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I suspect a computer issue, they do have tuners now.
BTW- Fuel injection and timing control are keyed off the distributor location, you can't just crank it about without screwing up the PCM's reference signal.
Re: 5.9 magnum hates mods? [Re: Mr.Yuck] #809916
09/21/10 08:18 AM
09/21/10 08:18 AM
Houston TX
GregCon Offline
GregCon  Offline
Houston TX
There could be many reasons, but for a start you are probably outside the operating range of one or more parameters in the PCM.
The simple fix would be to connect the PCM to your laptop and reprogram the initial values. Unfortunately, the PCM is not reprogrammable in that fashion - hence the need for a custom 'burn' and all the PITA associated with that.
Re: 5.9 magnum hates mods? [Re: Ultanium] #809917
09/21/10 08:19 AM
09/21/10 08:19 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If
"it idles rough and dies often"
then the pintle valve seat inside the EGR valve
may be so corroded that it is letting a lot of flow
all the time
At full throttle the EGR flow should be totally off
but if the pintle seat does not seal
that will lower your volumetric efficiency
and drop horsepower.
Re: 5.9 magnum hates mods? [Re: GregCon] #809918
09/21/10 08:23 AM
09/21/10 08:23 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
94-95 is the old style PCM, to take advantage of a hand held tuner you have to step up to 96 electronics so you can use a SCT tuner.
I'd double check your basics though before going there.
I have pointed out this thread to someone who has done a lot of Magnum modding, maybe he will chime in.
Re: 5.9 magnum hates mods? [Re: gdonovan] #809919
09/21/10 08:58 AM
09/21/10 08:58 AM
CT
b1llyw Offline
super street
b1llyw  Offline
super street
CT
Sounds to me like the fuel sync is way off. That combo should work fine with that PCM. Get your fuel sync set, see where that leaves you. You are probably borderline on injector sizing.
Bill White - BionicDodge.com
http://www.revelation320.org
Re: 5.9 magnum hates mods? [Re: b1llyw] #809920
09/21/10 09:37 AM
09/21/10 09:37 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Could his TB be too small? I mean what do those 2bbl (2 hole) flow? 500-600cfm max????
Re: 5.9 magnum hates mods? [Re: Mr.Yuck] #809921
09/21/10 09:43 AM
09/21/10 09:43 AM
CT
b1llyw Offline
super street
b1llyw  Offline
super street
CT
He would benefit from a larger throttle body but it's not small enough to cause these kinds of problems. I'd recommend this guy if he decides to upgrade.
http://stores.hi-potek.com/-strse-DAKOTA-cln-ENGINE-cln-Throttle-Body/Categories.bok
Re: 5.9 magnum hates mods? [Re: Mr.Yuck] #809922
09/21/10 10:23 AM
09/21/10 10:23 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Would not explain the idle issue, the throttle blades are closed.
At that point what the throttle body flows in a non-issue.
Start with the basics, set the fuel sync (distributor) which is critical for proper operation.
Re: 5.9 magnum hates mods? [Re: gdonovan] #809923
09/21/10 10:43 AM
09/21/10 10:43 AM
CT
b1llyw Offline
super street
b1llyw  Offline
super street
CT
Re: 5.9 magnum hates mods? [Re: Ultanium] #809924
09/21/10 12:21 PM
09/21/10 12:21 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I didn't think timing was adjustable...?
It's Swifty! Swifty, you toad sucker!
Re: 5.9 magnum hates mods? [Re: zrxkawboy] #809925
09/21/10 12:31 PM
09/21/10 12:31 PM
CT
b1llyw Offline
super street
b1llyw  Offline
super street
CT
You can play with the timing chain and/or crank sensor to play with base timing.
Re: 5.9 magnum hates mods? [Re: zrxkawboy] #809926
09/21/10 12:33 PM
09/21/10 12:33 PM
Bellville, Texas
U
Ultanium Offline OP
Ultanium  Offline OP
U
Bellville, Texas
Man, you guys are awesome! All good advice and I'm reading the PDF's from Bionic Dodge now, good stuff. I thought the Mopar Performance computer would be able to keep up with these mods, & if it was a '96 I would be able to flash it. I will get this thing synced this evening, and see what it does. What would be the next step up for injectors? I think I recall reading something about using blue ford injectors, but I cannot find it. Thanks again for all of the replies.
Tom in Texas
Re: 5.9 magnum hates mods? [Re: Ultanium] #809927
09/21/10 01:49 PM
09/21/10 01:49 PM
CT
b1llyw Offline
super street
b1llyw  Offline
super street
CT
No problem. Bruce is a Ford guy but his site is a good source for injectors.
http://www.fiveomotorsport.com/
Re: 5.9 magnum hates mods? [Re: b1llyw] #809928
09/22/10 12:03 AM
09/22/10 12:03 AM
Bellville, Texas
U
Ultanium Offline OP
Ultanium  Offline OP
U
Bellville, Texas
Well we think we have solved the rough idle problem. For several days I had a friend over tearing down the motor when we started this build. Well today we noticed a lot of jitter in the timing & misfires, so we went back to check the crank sensor and reluctor, and every hole was bent up so badly that it chewed the end of the sensor off.
With friends like that, who needs....
Re: 5.9 magnum hates mods? [Re: Ultanium] #809929
10/05/10 11:53 PM
10/05/10 11:53 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Remember, MT and AT crank Hall effect sensors are different lengths. Or...crank bolts loose?
Rick
Re: 5.9 magnum hates mods? [Re: Ultanium] #809930
10/05/10 11:56 PM
10/05/10 11:56 PM
Marlboro, NY, USA
Marlboro, NY, USA
...added a comp cams 262 roller (260/262 .480/512)
The project truck has a dead-stock 2001 cam.
Rick E.
Re: 5.9 magnum hates mods? [Re: Rick_Ehrenberg] #809931
10/06/10 10:17 AM
10/06/10 10:17 AM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
looks like a bar in the cps slots to rotate the ingine during build up ??
Thad
Page 1 of 3 1 2 3
