quick fuel q950 carbuertor #809886
09/21/10 12:00 AM
09/21/10 12:00 AM
Wisconsin
1964maxwedge Offline OP
Wisconsin
I'm trying to figure out what a positive throttle / gas pedal stop is? The directions say it is mandatory to use it . What I have is 1964 dodge 330 stock throttle set up for a big block.
Re: quick fuel q950 carbuertor [Re: 1964maxwedge] #809887
09/21/10 01:37 AM
09/21/10 01:37 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
just something to stop over pull,over center on carb butterfly when full throttle.this can cause butterflies to jam open
either have cable adjusted to suit or i have fitted a adjustable bolt to the floor under the accel pedal
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
