Electric fan thermal switch #80925
06/28/08 03:25 PM
06/28/08 03:25 PM
alberta
Publicbottle Offline OP
alberta
Need some help with my electric fan setup. i have a hole in my Mopar intake manifold that i am assuming is for a fan cut-out switch. Its a 7/16" NPT hole beside the temp sender unit. Now where can you get a thermal switch that turns the fan off? And what is a good temp to turn it off at?
Re: Electric fan thermal switch [Re: Publicbottle] #80926
06/28/08 03:37 PM
06/28/08 03:37 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I use the by pass hose port for mine. A lot of the deisel trucks have senders that you can use. Also Moroso has the sender in Summit.
Re: Electric fan thermal switch [Re: MoparforLife] #80927
06/28/08 09:21 PM
06/28/08 09:21 PM
alberta
alberta
what temp would you want your fan on? 195 degrees?
Re: Electric fan thermal switch [Re: Publicbottle] #80928
06/29/08 05:17 AM
06/29/08 05:17 AM
places
79powerwagon Offline
places
Mine is simply wired to run always. It only comes on after the engine has started (when I release the key from "Start" position). It's all done through relays, and works like a champ!
I had considered using a thermo switch, then I rationalized that the factory fan runs all the time, why shouldn't the electric too?
Hey, it least it's logic!
Re: Electric fan thermal switch [Re: 79powerwagon] #80929
06/29/08 12:24 PM
06/29/08 12:24 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The ON temperature is really up to you. It will be your highest number.
The OFF temp has to be higher than your thermostat temp or at least above normal operating temp as you run down the highway.
This is important because you don't want your fan running during highway cruise.
Re: Electric fan thermal switch [Re: Magnum] #80930
06/29/08 03:40 PM
06/29/08 03:40 PM
alberta
alberta
I just came a across a kit offered by painless.
They have 2 choices
1-fan on @ 200 off @ 185
2- fan on @ 185 off @ 170
i am thinking the 200 degree one would be best for my 340.
Re: Electric fan thermal switch [Re: Publicbottle] #80931
06/29/08 06:06 PM
06/29/08 06:06 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
What's your t-stat temp? I ran the Painless 200/185, and with a 180 t-stat, the fan never turned off.
Clair
Re: Electric fan thermal switch [Re: Clair_Davis] #80932
06/29/08 07:30 PM
06/29/08 07:30 PM
alberta
alberta
well i havent got a t-stat yet, i am still assembling my car, just added an afco rad & fan so i tought i would setup the switch at the same time. i doubt my car would ever run cooler than 185, thus the fan would never shut off. Hmmmmm this is weird. Would having the fan running on the highway help or hinder the airflow through the rad?
Re: Electric fan thermal switch [Re: Publicbottle] #80933
06/29/08 08:01 PM
06/29/08 08:01 PM
Upper Midwest
Upper Midwest
As far as that goes you can always go to a JY and get one off just about any late model car. A lot of them just pop into the radiator fins.
