NEON 2.0 INTERCHANGE
#808742
09/19/10 11:55 PM
09/19/10 11:55 PM
Posts: 10,651 S.E.Ohio
Magnumguy
S.E.Ohio
Friend's daughter messed up her 2000 Neon. He needs a 2.0 and tranny. What years can he scrounge from? 2000 up only?
Other models?
Re: NEON 2.0 INTERCHANGE
[Re: Magnumguy]
#808743
09/20/10 12:55 AM
09/20/10 12:55 AM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
The basic engine is the same as the 2.0 SOHC from 95 up but the intake is different from 95-99.
The trans depends on witch one you have, 3spd autos should all be interchangable, 5spd manuals should all be interchangable but there were a few different ratio sets available and if you have a 4spd auto you will be looking for 2000 up as the older ones only had the 3spd auto and 5spd manual.
[Re: HotRodDave]
#808744
09/20/10 12:57 AM
09/20/10 12:57 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
<snip>... if you have a 4spd auto you will be looking for 2000 up as the older ones only had the 3spd auto and 5spd manual.
the 4-speed began (in PLs) in 2001.
Rick
[Re: Rick_Ehrenberg]
#808745
09/20/10 01:46 AM
09/20/10 01:46 AM
HotRodDave
Kalispell Mt.
If he says it's so then it's so ![](/ubbthreads/images/graemlins/thumbs.gif) . I just thought the 4spd came out when the new body came out.
[Re: coronet1966d]
#808748
09/25/10 12:06 AM
09/25/10 12:06 AM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
95-2002 engines will interchange. the intakes are only different on 2000 and up but thats the only difference
The '95 engines have many differences from the '96-'99s- coil pack, valve cover, SOHC camshaft, EGR and evap. system, intake, etc.
For just a block, a few posts above is good advice. Keep the trans the same year if at all possible to avoid any differences with the PCM.
