NEON 2.0 INTERCHANGE #808742
09/19/10 11:55 PM
09/19/10 11:55 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Friend's daughter messed up her 2000 Neon. He needs a 2.0 and tranny. What years can he scrounge from? 2000 up only?
Other models?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: NEON 2.0 INTERCHANGE [Re: Magnumguy] #808743
09/20/10 12:55 AM
09/20/10 12:55 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The basic engine is the same as the 2.0 SOHC from 95 up but the intake is different from 95-99.
The trans depends on witch one you have, 3spd autos should all be interchangable, 5spd manuals should all be interchangable but there were a few different ratio sets available and if you have a 4spd auto you will be looking for 2000 up as the older ones only had the 3spd auto and 5spd manual.
Re: NEON 2.0 INTERCHANGE [Re: HotRodDave] #808744
09/20/10 12:57 AM
09/20/10 12:57 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
<snip>... if you have a 4spd auto you will be looking for 2000 up as the older ones only had the 3spd auto and 5spd manual.
the 4-speed began (in PLs) in 2001.
Rick
Re: NEON 2.0 INTERCHANGE [Re: Rick_Ehrenberg] #808745
09/20/10 01:46 AM
09/20/10 01:46 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If he says it's so then it's so . I just thought the 4spd came out when the new body came out.
Re: NEON 2.0 INTERCHANGE [Re: HotRodDave] #808746
09/20/10 10:09 PM
09/20/10 10:09 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
While the 99 and earlier engines are basically the same, it will be much less hassle to use a 2000 or newer. There were a lot of little changes that will have to be figured out. And while it is out and easy to get to, change the water pump and timing belt.
Master, again and still
Re: NEON 2.0 INTERCHANGE [Re: DaveRS23] #808747
09/20/10 11:30 PM
09/20/10 11:30 PM
Clinton Twp. Michigan
coronet1966d Offline
95-2002 engines will interchange. the intakes are only different on 2000 and up but thats the only difference
2003 and up engines will not work because the crank sensor is completley different, chrysler also changed computers and all electronics in 2003
Re: NEON 2.0 INTERCHANGE [Re: coronet1966d] #808748
09/25/10 12:06 AM
09/25/10 12:06 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
The '95 engines have many differences from the '96-'99s- coil pack, valve cover, SOHC camshaft, EGR and evap. system, intake, etc.
For just a block, a few posts above is good advice. Keep the trans the same year if at all possible to avoid any differences with the PCM.
