ECU wiring #80870
06/28/08 12:27 PM
06/28/08 12:27 PM
NE
O
Oldstrtracr Offline OP
O
NE
Will connecting blue wire with yellow tracer, to blue wire,and brown wire on ballest resister be correct, for getting power to ECU? Brown and blue wires come from ign. switch yes?? Thanks for the help.
Re: ECU wiring [Re: Oldstrtracr] #80871
06/28/08 01:01 PM
06/28/08 01:01 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: ECU wiring [Re: Oldstrtracr] #80872
06/28/08 01:11 PM
06/28/08 01:11 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
just to the blue wire. On START moment where the brown wire is the one being feeded directly from IGN, the ballast will splice the power back to from brown to the blue, enough to feed the ECU.
