motor has a demon in it #808310
09/19/10 08:12 PM
09/19/10 08:12 PM
wi
sixpaccornet Offline OP
wi
85 318 in a 72 dart,thanks for the info on removing weights on tc,i got em off.BIG BIG problem now.motor was running n timed great b4.had frontend up on stands too remove tc weights.runs like sh%t now.carb over loaded,black smoke,thick, it wont idle down revs up by itself and runs on after shut down????? help please.it has a demon 650 vac 2ndaries.rear float was way out off wack,adjusted it back. thanks jim
Re: motor has a demon in it [Re: sixpaccornet] #808311
09/19/10 09:38 PM
09/19/10 09:38 PM
florida
74fldart Offline
74fldart  Offline
florida
try to look into the carb as it idles and see if gas is running into it . you might have the float levels too high also you might check for a blown out power valve.
Re: motor has a demon in it [Re: sixpaccornet] #808312
09/19/10 09:45 PM
09/19/10 09:45 PM
a bit of debris that was holding the needle open
Re: motor has a demon in it [Re: RapidRobert] #808313
09/20/10 07:17 PM
09/20/10 07:17 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Demon has a motor in it...
