340 Coolant leak front of left head. Bad head gasket? #808132
09/19/10 03:31 PM
09/19/10 03:31 PM
Motor City
68cuda27 Offline OP
68cuda27  Offline OP
Motor City
Noticed a coolant leak at the base of my 340 left side head. Pressure testing the radiator showed the same leak. Any suggestions on the best process for pulling the left head off a '68 Barracuda with the high performance exhaust manifold with power brakes and power steering? Can I leave the manifold on the exhaust or do I need to drop the exhaust?
Re: 340 Coolant leak front of left head. Bad head gasket? [Re: 68cuda27] #808133
09/19/10 03:49 PM
09/19/10 03:49 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
depends alitle if the manifolds are using studs or bolts in the ends i would think... sure its not just a coreplugg in the end of the heads or the front ataching stud to the manifold?
Re: 340 Coolant leak front of left head. Bad head gasket? [Re: 1Fast340] #808134
09/19/10 04:05 PM
09/19/10 04:05 PM
Motor City
68cuda27 Offline OP
68cuda27  Offline OP
Motor City
I do have studs on the head for the exhaust manifold, and the core plug is not leaking. I leaks out the base of the head.
Re: 340 Coolant leak front of left head. Bad head gasket? [Re: 68cuda27] #808135
09/19/10 05:00 PM
09/19/10 05:00 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
the studs can make it alitle harder to get the heads of with the exhaust still there, i have not tried this mysels since everything i own has headers
Re: 340 Coolant leak front of left head. Bad head gasket? [Re: 1Fast340] #808136
09/19/10 10:14 PM
09/19/10 10:14 PM
might have studs on the front/rear ex port holes and bolts on the rest. Will need to split the ex pipe and take off the inside bolts/washers and the nuts/washers off of the front and rear stud then remove the ex manifold. (dont forget to drain the coolant down a bit). If the ex man cannot be totally removed WO r&r ing the ps box then see if it can be moved over enough for you to R&R the head. EDIT the front and rear bolt holes (only) are wet (SB)
Re: 340 Coolant leak front of left head. Bad head gasket? [Re: RapidRobert] #808137
09/19/10 10:23 PM
09/19/10 10:23 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
It's not worth the hassle to fight it. been there-done that
drop the head pipe and pull the manifold off the car and get it out of the way
Re: 340 Coolant leak front of left head. Bad head gasket? [Re: gtx6970] #808138
09/19/10 10:30 PM
09/19/10 10:30 PM
scratchnfotraction Offline
I would double check it myself
i have had the t-cover gasket leak right by the base of the head
also have had the intake gasket leak right in the corner where the head/block/intake meet
just make sure its the head gasket before pulling the head,make sure the water is not traveling to the gasket line from else where
