Re: Main Bearing Help!
[Re: snook]
#807954
09/19/10 12:57 PM
09/19/10 12:57 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If your crakn has chamfers and the bearings are too wide they could be hitting the edge of the curve and locking it up.
[Re: Cab_Burge]
#807957
09/19/10 04:31 PM
09/19/10 04:31 PM
Posts: 622 NC
chris3
NC
More news. The bearing are set back such that the edges are not hitting the champher on the crankshaft. Set the crank shaft in place turns free. Took the crank back out removed the center thrust bearing. Set the crank back in place. Checked end play with the shaft in place on the bearings and would move laterally and turn smooth. Put all of the caps on. Torqued the studs to 15 foot pound and the crank would not turn. Took each cap off, one at a time, and crack would not turn until the last cap was removed. This crank has been checked for straight, the journals turn .010, polished and balanced. Only possible thought at this point is that the caps are not aligning with the crankshaft. Thanks MOPART for all of your help. Anyone else got any ideas.
[Re: chris3]
#807958
09/19/10 08:19 PM
09/19/10 08:19 PM
Posts: 622 NC
chris3
NC
[Re: chris3]
#807962
09/19/10 11:52 PM
09/19/10 11:52 PM
Posts: 43,205 Bend,OR USA
Cab_Burge
There is only a cuople of reasons the crank won't turn, there's not enough clearnances on either the main bearings or the thrust clearnance or the crank is bent I would start at the front of the block and tighten #1 main cap down at a time and see if the crank will rotate, if not remove it and do #2 and then # 3 and so on. If the crank won't turn with any of the caps tight you may have a main web bore needing align honing or align boring as a result of the block being out of alignment on the mains. Over heating the block can cause this, usually the main caps will not have any inteference fit in the block if that happens Do your main caps fit loosely or do you have to tap them into place or use the bolts to make them fit into the main saddles ? BTW, when it comes to assembling and blueprinting motors everything has to be checked, every machine shop and machinest as well as mechanics makes mistakes, it is the engine assemblers job to find the mistakes and get them corrected before the motor is ran the first time your being tested on this one, you can and will figure it out Let us know what you find and what it takes to fix it
[Re: chris3]
#807964
09/20/10 10:42 AM
09/20/10 10:42 AM
Posts: 2,091 Delray beach, Florida
Performance Only
put the crank in the block and torque main caps 1,2,4 and 5 install #3 cap without the lower shell and torque it. see if the crank spins freely. i'm guessing it will.
machine shop owner and engine builder
[Re: Performance Only]
#807965
09/20/10 10:53 AM
09/20/10 10:53 AM
Posts: 7,506 Az
Crizila
Az
Dumb question at this point, but did you mike the bearing shells to make sure they are actually 10 over?
Fastest 300
[Re: Crizila]
#807967
09/20/10 11:23 AM
09/20/10 11:23 AM
quick77rt
Parts Problem
Parts Problem
A long shot? Has the block ever been align bored? If so you might check the bearing tangs to see if they are now too big to let the bearing sit right in the block. I had the no turn problem, I made it turn, pulled the crank, seen the two areas it was tight, used a small file on the bearing half just a bit, installed the crank with no further issues.
[Re: chris3]
#807969
09/20/10 01:39 PM
09/20/10 01:39 PM
Posts: 438 Great Lakes Region
abodiesonly1
Great Lakes Region
The main caps do not just sit down in the block. You have to give them just a slight tap and they will go in place.
With no main caps installed the crank will turn free. I installed the #1 cap, torqued it down and the crank would not turn. Took that cap off and installed the #2 cap and it would not turn. Did this to every single cap and the crank would not turn. Crank will not turn with any cap in place.
Removed the #3 main thrust bearing and cap. Set the crank in place. Crank will turn free. Install #1 cap and torque it down and the crank will not turn.
I will check the run out on the crankshaft tonight; however, I believe that I will have to have this motor align honed to get this right.
Yes we will get it fix; however, it has cost us another week-end. If we had not already spent so much money on this block, I would have set it aside and worked on another. Thanks for all of the help MOPARTS and if anyone has any ideas please let me know.
With the crank in place, and only 1 cap installed and torqued, it has to be a bearing problem.
[Re: chris3]
#807971
09/21/10 09:14 AM
09/21/10 09:14 AM
Posts: 622 NC
chris3
NC
