Best and Safest Way to Remove Paint for Resto #807885
09/19/10 09:53 AM
09/19/10 09:53 AM
Ohio
RestoreCuda Offline OP
Ohio
What is the best and safest way to strip paint from a car? Chemical Stripper/Media Blasting/Aluminum Oxide Blasting? I have chemically stripped a car before and think that may be best to protect the body panels. What do all of you think? Thanks.
Re: Best and Safest Way to Remove Paint for Resto [Re: RestoreCuda] #807886
09/19/10 11:34 AM
09/19/10 11:34 AM
Canfield,Ohio,USA
gassy66 Offline
gassy66  Offline
Canfield,Ohio,USA
Get Yourself a low speed circular buffer(not an ocillating one) like Body Shops use for buffing,a Pad that takes 8" stick on 36 grit discs,and grind off all the paint without attacking the metal under the paint..If You have a good Air
Compressor,You then sand blast the Car using no more than 140 lbs air pressure and a fine grit of
sand...
Re: Best and Safest Way to Remove Paint for Resto [Re: gassy66] #807887
09/19/10 11:40 AM
09/19/10 11:40 AM
Ohio
Ohio
Thanks, as you know I don't want to distort the body panels.
Re: Best and Safest Way to Remove Paint for Resto [Re: RestoreCuda] #807888
09/19/10 12:00 PM
09/19/10 12:00 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
if you dont want to distort, DONT BLAST.
Use chemical stripper, scraper, and then sand with an orbital sander. then epoxy prime with something like ppg dp40.
Re: Best and Safest Way to Remove Paint for Resto [Re: domingo] #807889
09/19/10 12:03 PM
09/19/10 12:03 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
have it plastic media blasted, works like a charm and doesn't distort any metal. plus it doesn't hurt any attached trim or glass
Re: Best and Safest Way to Remove Paint for Resto [Re: gtx6970] #807890
09/19/10 12:07 PM
09/19/10 12:07 PM
maine
LO23 Offline
LO23  Offline
maine
Re: Best and Safest Way to Remove Paint for Resto [Re: LO23] #807891
09/19/10 12:16 PM
09/19/10 12:16 PM
Ohio
Ohio
Thanks, not sure where to get it media blasted but I will check it out. If I were to use chemical stripper who makes a good product?
Re: Best and Safest Way to Remove Paint for Resto [Re: RestoreCuda] #807892
09/19/10 01:15 PM
09/19/10 01:15 PM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
Please be kind to that old car and DO NOT use a coarse grinding disc or anything that coarse to remove that paint. I think that is just about the worst thing you can do to the base metal. NAPA makes a very powerful paint stripper and it takes the old finish right off. Last gallon I bought was around $42 but that gallon will remove a lot of paint since it cuts well. Best to use outside in the shade IMO. Media blasting or even soda blast will be very kind to the metal surface. Deep crusty rust will still need something coarser to get it clean but I think your way ahead of the game by using the least invasive approach but, to each his own! JC.
Re: Best and Safest Way to Remove Paint for Resto [Re: RestoreCuda] #807893
09/19/10 02:02 PM
09/19/10 02:02 PM
California
1970mopar Offline
1970mopar  Offline
California
AIRCRAFT STRIPPER is the best (thats a name brand)
I would definately look into plastic media blasting and/or Soda blasting -
Consider that you'll spend quite alot of time and material (stripper and sand paper) to completely remove all the paint off your cars body (not to mention the hazardous waste that's left over).
Having it properly blasted is generally "cheaper" (as in easier for you with less hassle.) Most places will also Epoxy Prime right after blasting giving you a ready to start on project that's clean.
Just remember All methods have +'s and -'s. Weigh your options before you decide
Re: Best and Safest Way to Remove Paint for Resto [Re: 1970mopar] #807894
09/19/10 02:05 PM
09/19/10 02:05 PM
Ohio
Ohio
Thanks a lot
Re: Best and Safest Way to Remove Paint for Resto [Re: RestoreCuda] #807895
09/19/10 03:15 PM
09/19/10 03:15 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
blast it. save the toxic mess for somebody else.
here is a youtube vid with me on my demon using soda. there are a couple videos of it.
cuda i did for a friend. soda w/ crushed glass on the floors and underhood.
demon
Re: Best and Safest Way to Remove Paint for Resto [Re: gassy66] #807896
09/19/10 03:22 PM
09/19/10 03:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
sand...
Holly Cow!! 140psi....?
If your using that much psi, you don't have the volume you need.
I blast at no more than 80-90 PSI max. Plastic I blast at 40 PSI.
IMO Blasting is best, plastic on the outter panels, something more aggressive for the bottem and rusty areas.
In order to blast the car, it must be totally stripped. If that's not possible then you shouldn't blast, soda or other wise IMO.
Re: Best and Safest Way to Remove Paint for Resto [Re: RestoreCuda] #807897
09/19/10 03:42 PM
09/19/10 03:42 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I just had this car done last week...
It was 100% soda blasted inside and out, top to bottom. Then in the real rusty spots it was sand blasted. Finished off with a nice completely covering coat of epoxy primer.
I don't have time for a toxic mess of scrapping old paint, beside you can't get in the nooks and crannys very well.
CHECK OUT MY NEW WEB SITE !
Re: Best and Safest Way to Remove Paint for Resto [Re: QuickSilver] #807898
09/19/10 04:07 PM
09/19/10 04:07 PM
Cincinnati, Ohio
Cincinnati, Ohio
Did you ever see that TV show where Kenny Wayne Shephard did a restomod to a old charger? That body looked like someone took a metal grinder to it with a abrasive stone wheel! I bet the painter of that car freaked out when he saw that. That was all the wrong way to strip that car, just crazy.
Re: Best and Safest Way to Remove Paint for Resto [Re: RestoreCuda] #807899
09/19/10 04:37 PM
09/19/10 04:37 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I have tried all methods and I prefer sandblasting for a rotissary job. If done correctly, the job won't cost much, and the surface rust as well as paint and undercoating will be removed.
Unlike other blasting media, the resulting surface is etched and clean, and does not need to be scrubbed/treated for adhesion purposes.
An experienced blaster will not warp the sheetmetal.
Re: Best and Safest Way to Remove Paint for Resto [Re: DoctorDiff] #807900
09/19/10 04:50 PM
09/19/10 04:50 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
If you can afford to have it media blasted, then that (IMHO) is the best method.
Joe
65 Barracuda
70 Challenger
Re: Best and Safest Way to Remove Paint for Resto [Re: RestoreCuda] #807901
09/20/10 10:14 AM
09/20/10 10:14 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Best way. Chemical dunk then e coat dunk. Very expansive though. Next best. Chemical by hand. Then very little blasting on needed areas, hard to reach areas and corrosion. Next for me is soda. While plastic does a good job it will be falling out of the body for years. You can not get it all out of the blind spots. At least plastic does not absorb moisture in tight places like sand does.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Best and Safest Way to Remove Paint for Resto [Re: sixpackbee] #807902
09/20/10 03:49 PM
09/20/10 03:49 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I agree.
Re: Best and Safest Way to Remove Paint for Resto [Re: HEMICUDA] #807903
09/20/10 09:39 PM
09/20/10 09:39 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
redi-strip did this cuda fender. it was around $250 for dip and e coat it.
as you can see not the best job.
Re: Best and Safest Way to Remove Paint for Resto [Re: chrisf] #807904
09/20/10 10:43 PM
09/20/10 10:43 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
E-coat? Where?
