What do you mean it smells like its running hot #80777
06/28/08 12:42 AM
06/28/08 12:42 AM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Had a friend of mine following me in my Wagon tonight on the highway. We stopped at our destination,and he asked if my car was running hot? My Temp gauge didnt indicate it,so I wasnt alarmed.
What does a car thats running "hot" smell like?
I have noticed at times though that my temp gauge will go to the middle for a while,climb,then go back to the center all while driving at highway speeds.(Whats up with that?)
Re: What do you mean it smells like its running hot [Re: SPWC] #80778
06/28/08 12:56 AM
06/28/08 12:56 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
it smells like hot antifreeze leaking. I have it in my Jeep sometimes.
Re: What do you mean it smells like its running hot [Re: sharpie] #80779
06/28/08 01:48 AM
06/28/08 01:48 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
It cools down on the highway because of the extra air going through the radiator and a constant relatively low (like 2400 in your case probably) RPM.
My temp gauge goes on and off all the time, who knows how accurate they are either? Thats why I have the aftermarket gauges.
Re: What do you mean it smells like its running hot [Re: GTX MATT] #80780
06/28/08 11:57 AM
06/28/08 11:57 AM
burning oil & boiling coolant do have distinctive smells.
Re: What do you mean it smells like its running hot [Re: SPWC] #80781
06/28/08 01:44 PM
06/28/08 01:44 PM
toronto canada
69chargeryeehaa Offline
toronto canada
common problem is the exhaust manifolds studs leaking, burning the coolant on the hot manifolds......
Re: What do you mean it smells like its running hot [Re: SPWC] #80782
06/28/08 02:16 PM
06/28/08 02:16 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
In Az they smell hot just sitting there in the parking lot........
Re: What do you mean it smells like its running hot [Re: SPWC] #80783
06/28/08 03:12 PM
06/28/08 03:12 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Sometimes running lean has a distinctive smell (for me it reminds me of paint thinner or stale gasoline)
Re: What do you mean it smells like its running hot [Re: anmracing] #80784
06/28/08 07:29 PM
06/28/08 07:29 PM
that's because of the "dry" heat right
Re: What do you mean it smells like its running hot [Re: SPWC] #80785
06/28/08 08:05 PM
06/28/08 08:05 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Ive had many stockers do that, I always thought it was just the t-stat at work...sorta like the when the first ele cooling fan cars came out, the gauge would go up, fan kicked on and it would go down a bit?????????
Re: What do you mean it smells like its running hot [Re: quick77rt ] #80786
06/28/08 09:48 PM
06/28/08 09:48 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
more likely a cheap thermostat. They almost all are cheap, and when they open, they should stay open, but I'm sure some have a hard time keeping steady state, and probably open and close to some degree during operation.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
