Re: Eliminating throttle cable assembly
[Re: markz528]
#807702
09/19/10 01:41 PM
09/19/10 01:41 PM
Posts: 4,209 New York
polyspheric
New York
Bellcranks also allow tuning-in a degree of progression or "nervousness" by changing the clocking of the arms vs. pivot position. You can make the throttle much less sensitive to small changes at idle for tight staging and launch, and still easily reach WOT without changing your carburetor lever arm. More: http://victorylibrary.com/mopar/TB-linkage.htm
Boffin Emeritus
