torq main bearing cap specs.........dAMit #807524
09/18/10 09:20 PM
09/18/10 09:20 PM
ca, slo.
P
paulyvault Offline OP
P
ca, slo.
ok long story short and dont ask why, i only torqed one of my main bearing caps down to 75foot pounds and the rest to 85 foot pounds, will that make a big diff or should i take [Edited by Moparts - Family Friendly Site - Keep it clean] apart and torq the 75lbs to 85? [Edited by Moparts - Family Friendly Site - Keep it clean]!
Re: torq main bearing cap specs.........dAMit [Re: paulyvault] #807525
09/18/10 09:28 PM
09/18/10 09:28 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
What type of motor? Stock rebuilt? High performance? Race intentions?
As you know, the torque can affect the bearing crush which could affect the bearing clearance. Did you take any measurements during the assembly? How tight were the bearings to begin with?
Is the motor already in the car?
Re: torq main bearing cap specs.........dAMit [Re: paulyvault] #807526
09/18/10 09:33 PM
09/18/10 09:33 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
So long as the bearing shells are tight enough against each other to form a perfect circle then your ok. If you ever bolt a crank into a block and try to turn it with the main bolts not being at least close to fully tight you'll find the crank won't turn over because the bearings are in an elipse rather than a perfect circle. When the bearings ends touch they push the rest of the bearing tight to the main journals.
If I had to bet money I'd say it's ok since 10 ft lbs isn't a lot. Better the crank bolt than a rod bolt....
Re: torq main bearing cap specs.........dAMit [Re: davenc] #807527
09/18/10 10:34 PM
09/18/10 10:34 PM
ca, slo.
P
P
ca, slo.
383 just board 10 over. not HP. thanks
Re: torq main bearing cap specs.........dAMit [Re: paulyvault] #807528
09/18/10 10:48 PM
09/18/10 10:48 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Did you rotate the crank during assembly without the oil seal in place? If it turned nice and free, then I would not worry about it.
Re: torq main bearing cap specs.........dAMit [Re: davenc] #807529
09/18/10 10:54 PM
09/18/10 10:54 PM
ca, slo.
P
P
ca, slo.
did a little rotation when i was putting new main bearings in, then after they were all in just checked it to see if it would rotate and it went fine. so thats what the deal is.
Re: torq main bearing cap specs.........dAMit [Re: paulyvault] #807530
09/19/10 01:17 AM
09/19/10 01:17 AM
ca, slo.
P
P
ca, slo.
anybody else out there have any suggestions? thanks
Re: torq main bearing cap specs.........dAMit [Re: paulyvault] #807531
09/19/10 02:35 AM
09/19/10 02:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You know what you SHOULD do , just do it and be done with it .
Re: torq main bearing cap specs.........dAMit [Re: JohnRR] #807532
09/19/10 08:46 AM
09/19/10 08:46 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
There's a reason for specifying fastener torques, to get the design holding forces. This isn't the place to cut a corner.
