Are there any "bolt-in" sure grips for the 8.75" #80606
06/27/08 05:53 PM
06/27/08 05:53 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
Wondering if there are any bolt in solutions for an open rear? It is an 8.75 and has an 489 case. I was looking at a locker that allowed turning, but not sure if that is the answer?
Re: Are there any "bolt-in" sure grips for the 8.75" [Re: hemibeep] #80607
06/27/08 05:54 PM
06/27/08 05:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Dr.Diff on the board has new sure grip units for sale that are a true retro fit.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Are there any "bolt-in" sure grips for the 8.75" [Re: hemibeep] #80608
06/27/08 06:22 PM
06/27/08 06:22 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
Powertrax Lockrite Lockers are supposed to be bolt-in and good units from what I've heard. For as much as you'll spend on one though you might as well drop a little extra coin and just buy a new Power-lock suregrip, or Detroit True-Trac, or a Detroit Locker and pay the hundred bucks to have it set up right unless you can set it up yourself.
Re: Are there any "bolt-in" sure grips for the 8.75" [Re: hemibeep] #80609
06/27/08 06:27 PM
06/27/08 06:27 PM
Moonraker Offline
Moonraker  Offline
You can also use a mini spool but be careful around the corners
Re: Are there any "bolt-in" sure grips for the 8.75" [Re: Moonraker] #80610
06/27/08 08:55 PM
06/27/08 08:55 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
They're all bolt in.... If your asking can you replace the spiders with a locking unit and not disturb the carrier? No such animal that I've ever heard of. The powertrax are aggressive, noisy, and not really much cheaper then the new clutch type sure grips Dr. Diff sells. You'll not go wrong dealing with him. His reputation is impeccable here. Hope he chimes in
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Are there any "bolt-in" sure grips for the 8.75" [Re: R70RUNNER] #80611
06/27/08 10:17 PM
06/27/08 10:17 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes, I just bought a quantity of repro clutch type power-lock differentials. They don't cost much more than a lock-rite.
