stock mufflers on 300c or magnum anyone in dfw? #80576
06/27/08 04:21 PM
06/27/08 04:21 PM
Andrewh Offline OP
Andrewh  Offline OP
What are the stock mufflers on those? Can you purchase them new or USED ?
Will they fit under a 65 b-body?
Anyone in DFW do an exhaust upgrade and keep the old mufflers?
Re: stock mufflers on 300c or magnum? [Re: Andrewh] #80577
06/27/08 08:22 PM
06/27/08 08:22 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
They seem pretty massive from what I've read, and I bet there are folks on the LX Forums that are giving them away... The system isn't bad for size, but I don't think they flow super well. HP gains from system swaps don't seem to be very high for the money spent.
Clair
Re: stock mufflers on 300c or magnum? [Re: Clair_Davis] #80578
06/27/08 09:19 PM
06/27/08 09:19 PM
Andrewh Offline OP
Andrewh  Offline OP
wasn't looking for performance gains.
Just hoping to get some ideas on quite exhaust.
I keep reading about how people change them out because they can't hear their cars run.
They have to breath a bit for the hemi, so I figure it would be a good way to go for my swap.
Re: stock mufflers on 300c or magnum? [Re: Andrewh] #80579
06/28/08 01:57 AM
06/28/08 01:57 AM
I'd just get some regular turbo mufflers from summit or jegs, they are fairly quite and flow pretty well.
I have Jegs turbo mufflers on my RR and it is very quite just a slight rumble.
Re: stock mufflers on 300c or magnum anyone in dfw? [Re: Andrewh] #80580
06/28/08 09:50 PM
06/28/08 09:50 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
The center mufflers on an LX car are about as big as a suitcase hence the nickname, it's actually 2 mufflers in 1 case, the way it's designed you would have to mount it under the trunk floor, it wouldn't fit in a car with a solid axle in the normal location.
The rear resonators are kinda form fitted to the floor and wrap up around the side of the car a bit.
The center muffler is 2.25" in and out the resonators are 2.25 in with tips welded on the rear.
If it were me I'd use a long case dynomax turbo, it should fit fine and be quiet.
Re: stock mufflers on 300c or magnum anyone in dfw? [Re: MoparJoe] #80581
06/29/08 02:00 PM
06/29/08 02:00 PM
Andrewh Offline OP
Andrewh  Offline OP
Thanks. that is the first time I had seen any dimensions on them.
