98 360 Stall problem Fuel starved? Help. #80558
06/27/08 02:55 PM
06/27/08 02:55 PM
Hudson Mass
67Mopar Offline OP
67Mopar  Offline OP
Hudson Mass
Any advise would be appreciated, new coil done, throttle body done, fuel regulator, and pump done, Im just about done, runs fine cold, then bogs out after it is warmed up and I hit my first stop sign. THanks
Re: 98 360 Stall problem Fuel starved? Help. [Re: 67Mopar] #80559
06/27/08 06:42 PM
06/27/08 06:42 PM
distributor pick up and/or crank sensor.
both very common.if you get me your vin I
can get you some part numbers.
pick up 56028143 list 55.45
auto trans crank sensor 56027870 98.50 list
stick trans crank sensor 56027871 98.50 list
special discount for Massmopar members!
Re: 98 360 Stall problem Fuel starved? Help. [Re: 67Mopar] #80560
06/28/08 09:14 AM
06/28/08 09:14 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
More of a detailed description might help narrow things down. Ie will it restart, immediatley or not? Any popping/backfiring...intake or exhaust?
When you say it bogs this leads me to believe you may have a fuel system issue. With ignition failures you may see backfiring or have it cut off cleanly. Stumbling is more an indication of a poor fuel mixture or a problem that simulates one.
You replaced the fuel pump and regulator, but did you check fuel pressure first? Have you checked for vacuum leaks? If it stumbles/bogs as you stop is your brake booster bad? Could the EGR have stuck open? Checked to make sure the IAC is not sticking/gummed up?
Any codes? A torque convertor not unlocking can kill yor engine ...if you were going that fast
Good luck.
Re: 98 360 Stall problem Fuel starved? Help. [Re: UCUDANT] #80561
06/28/08 10:25 AM
06/28/08 10:25 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you had it read for codes?
Re: 98 360 Stall problem Fuel starved? Help. [Re: stumpy] #80562
06/30/08 09:44 AM
06/30/08 09:44 AM
Hudson Mass
67Mopar Offline OP
67Mopar  Offline OP
Hudson Mass
The fuel pressure was way up which led us to believe it was overloading and bogging out due to a bad regulator, now it does fire right up and will idle no cracking or backfireing there does seem to be a loud sucking noise somewhere in the engine compartment, but I cant find a leak, the brake booster thought is a good one, ive been suspect about my brakes for yrs,. It is possible that I kinked a line stuffing the tank back in but I am smelling some burning and looking for a probable ground issue, which could take yrs to find. total pain in the butt on this one.
Re: 98 360 Stall problem Fuel starved? Help. [Re: 67Mopar] #80563
06/30/08 10:36 AM
06/30/08 10:36 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
I wonder if you have a blown intake manifold plenum cover gasket. Is it using oil? Hughes sells a reinforcement kit for the problem.
Re: 98 360 Stall problem Fuel starved? Help. [Re: Reggie] #80564
06/30/08 12:54 PM
06/30/08 12:54 PM
Hudson Mass
67Mopar Offline OP
67Mopar  Offline OP
Hudson Mass
Ruled out that one but because of the lack of oil usage
Re: 98 360 Stall problem Fuel starved? Help. [Re: 67Mopar] #80565
06/30/08 01:16 PM
06/30/08 01:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thats not completely true
i would give moparts bob your VIN and have him see if it was done under warranty .
as far as your brakes , its a 98 2500 , the brakes just plain blow on that model year truck , if the booster was bad you would have a very hard to push peddle , is this the case ?
Re: 98 360 Stall problem Fuel starved? Help. [Re: 67Mopar] #80566
06/30/08 01:37 PM
06/30/08 01:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Bad battery....
Re: 98 360 Stall problem Fuel starved? Help. [Re: NITROUSN] #80567
06/30/08 01:57 PM
06/30/08 01:57 PM
Hudson Mass
67Mopar Offline OP
67Mopar  Offline OP
Hudson Mass
Bad battery....
Its not the best for sure but Id like to hear more.
Thanks all.
Re: 98 360 Stall problem Fuel starved? Help. [Re: 67Mopar] #80568
06/30/08 03:38 PM
06/30/08 03:38 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Bad battery....
Thanks all.
If the battery is weak it will cause issues. The computer loses its adaptive memory if the voltage drops to low esp while cranking.
