jack paint #80532
06/27/08 01:30 PM
06/27/08 01:30 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
I need to restore my jack and it was an originally a gray color. Where can I get a can of spray to match that particular gray. Thanks
Re: jack paint [Re: 70 buzz] #80533
06/27/08 04:38 PM
06/27/08 04:38 PM
Detroit, MI
FC7AARcuda Offline
FC7AARcuda  Offline
Detroit, MI
What I did was take the jack base to the hardware store and found the grey non-sandable primer in a rattle can closest to the original grey paint. I then sprayed clear over the primer. It came out very close to the original color and the grey primer and clear were about a $1 a can, so it was cheap.
Re: jack paint [Re: 70 buzz] #80534
06/27/08 04:42 PM
06/27/08 04:42 PM
KY
65pacecar Offline
65pacecar  Offline
KY
I have a friend that works at Square D. making control boxes. He can buy their gray paint in the spray can at cost, it is the exact color of the original jack. Not sure if it is available on the market, if you can find it you will be surprised how close it is.
Re: jack paint [Re: 65pacecar] #80535
06/27/08 11:17 PM
06/27/08 11:17 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Krylon Stone Gray
logan426
Re: jack paint [Re: MLR426] #80536
07/06/08 07:41 PM
07/06/08 07:41 PM
South Carolina
sixpackbird Offline
sixpackbird  Offline
South Carolina
Dupli-Color Dove Gray touch up paint at your local auto parts store, I think the number is EDSFM167, almost an exact match.
Re: jack paint [Re: sixpackbird] #80537
07/06/08 10:16 PM
07/06/08 10:16 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Dove gray has been superceded with Stone gray.
logan426
