Page 10 of 19 1 2 8 9 10 11 12 18 19
Re: 514 on the dyno [Re: AndyF] #804352
11/03/11 06:48 PM
11/03/11 06:48 PM
AndyF Offline OP
AndyF  Offline OP
Here is another picture of the intake. They removed the clover leaf and added length to the runners. The intake is also lighter than before so they must have removed a fair amount of material in the runners.
Re: 514 on the dyno [Re: AndyF] #804353
11/03/11 07:43 PM
11/03/11 07:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Nice to see they didn't razor edge the dividers like some hacks like to do.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 514 on the dyno [Re: pittsburghracer] #804354
11/03/11 08:09 PM
11/03/11 08:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed............Ed even mentioned that to me about how a generous radios directs the air/fuel and a sharp edge confuses it. My intake however is WAY rough in texture..............maybe wilson thinks the "pretty" look is more impressive but definately not as good at atomizing the intake charge.
Re: 514 on the dyno [Re: AndyF] #804355
11/03/11 09:06 PM
11/03/11 09:06 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
the "if it were me" response is.......i would get another OOTB intake so i could do a back to back test against the ported one.
Re: 514 on the dyno [Re: fast68plymouth] #804356
11/04/11 03:30 AM
11/04/11 03:30 AM
Mo.
racerx Offline
racerx  Offline
Mo.
That would be a interesting comparison
Re: 514 on the dyno [Re: fast68plymouth] #804357
11/04/11 08:39 AM
11/04/11 08:39 AM
an8sec70cuda Offline
I'd really like to see that.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 514 on the dyno [Re: an8sec70cuda] #804358
11/04/11 11:50 AM
11/04/11 11:50 AM
Idaho
LaRoy Engines Offline
Idaho
Money, money, money, its a rich man's world. Who is the sport that's buying the $370 manifold for this comparison test?
Re: 514 on the dyno [Re: LaRoy Engines] #804359
11/04/11 12:01 PM
11/04/11 12:01 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I was thinking the same thing. But maybe someone could donate one for the test, then return it. If I decide to pull down the top end over the winter, I may even consider.
Re: 514 on the dyno [Re: AndyF] #804360
11/04/11 12:10 PM
11/04/11 12:10 PM
AndyF Offline OP
AndyF  Offline OP
Here is a side by side shot showing unported vs. ported.
Re: 514 on the dyno [Re: AndyF] #804361
11/04/11 12:43 PM
11/04/11 12:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So, not only was it ported but the dividers were extended into the plenum............
Re: 514 on the dyno [Re: AndyF] #804362
11/04/11 02:56 PM
11/04/11 02:56 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Sense there both there a comparison would be nice
Re: 514 on the dyno [Re: Thumperdart] #804363
11/04/11 06:47 PM
11/04/11 06:47 PM
AndyF Offline OP
AndyF  Offline OP
Yes, they did a ton of work to the intake. The dividers were extended, the plenum shape was changed, and the runners were ported for the entire length. This is one of their competition port packages.
Re: 514 on the dyno [Re: AndyF] #804364
11/04/11 07:21 PM
11/04/11 07:21 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Are you ever going to put this motor in a car and run it? Or are you putting wheels on that dyno.Your engine has not gone down the track and you are allready talking about putting different rods in it. If your going to bench race you will need a longer bench.
Re: 514 on the dyno [Re: WheelsUp73] #804365
11/04/11 10:58 PM
11/04/11 10:58 PM
AndyF Offline OP
AndyF  Offline OP
This one is a dyno motor. My car has a different motor in it.
Re: 514 on the dyno [Re: WheelsUp73] #804366
11/05/11 10:12 AM
11/05/11 10:12 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Andy's giving out EXCELLENT information...along with pics,and "DO-NOTHINGS" like you have to throw your little wize-azz remarks in! I don't get it! I'm sure this is why more than a FEW knowledgeable people stay away from this site!
Re: 514 on the dyno [Re: Labratt] #804367
11/05/11 11:29 AM
11/05/11 11:29 AM
gregsdart Online content
gregsdart  Online Content
Lab, good to speak up. Knowledge like that is hard won and I appreciate it a great deal, as do many, looking from the post count.
I wish I had the $$ to do a dyno motor like this- then after many, many changes build another motor based on everything I learned and run THAT one!
Re: 514 on the dyno [Re: Labratt] #804368
11/05/11 11:41 AM
11/05/11 11:41 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Need I ask who u are refuring to? Is it the crazy wheelstanding lady by chance?
Re: 514 on the dyno [Re: Thumperdart] #804369
11/07/11 01:03 PM
11/07/11 01:03 PM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Dom,it was directed to WheelsUp 73!...didn't know it was a LADY! That doesn't really matter....women can be wise-GUYS as well as men!
Re: 514 on the dyno [Re: Labratt] #804370
11/07/11 01:43 PM
11/07/11 01:43 PM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Andy, what rpm have you gone up to? Also, is the power curve still rising at the end of the pull. In theory, if the heads/cam combo can support the higher rpm, one would assume there maybe more power available but I don't know if that would higher rpms would suit this motor with the 4.15 stroke. I would think 8500(or a lil higher) maybe the highest plateau but who knows, I'm not a skilled engine builder like you guys, just a young student.
Adriel Paradise
Substation Design Engineer III
Re: 514 on the dyno [Re: Labratt] #804371
11/07/11 02:33 PM
11/07/11 02:33 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Let's stay on topic here..
