Re: 514 on the dyno
[Re: AndyF]
#804175
09/18/10 09:02 AM
09/18/10 09:02 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
OK, you definitely have our interest! Can you give us a full run down of the head flow, valve size, lift of cam, type of springs, etc? 650 is some very good territory. How close to a proper tune do you think you got?
Re: 514 on the dyno
[Re: AndyF]
#804178
09/18/10 11:33 AM
09/18/10 11:33 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Sounds like an awesome engine Andy!
2 kids and a dog
Re: 514 on the dyno
[Re: AndyF]
#804179
09/18/10 11:34 AM
09/18/10 11:34 AM
Posts: 16,928 NC
440Jim
NC
Indy EZ heads.
Are those the CNC ported EZ, max wedge, 1.8 Jessel etc that you used on another build?
Re: 514 on the dyno
[Re: AndyF]
#804187
09/19/10 12:44 PM
09/19/10 12:44 PM
gregsdart
Pardon the typo in my previous reply. 850 hp is definitely a step above. Your combo is using less cam, less compression, less cubes than most any 850 hp combo on the board, if I have followed all the right posts. Our (or at least my) interest is in how the philosophy of this engine build can be duplicated and used to increase hp on bigger motors as well. Your use of the EZ heads with less exhuast flow than a 440-1 is interesting. It points to the possiblity I should go back to a cam with less duration on the exhaust. Same with the rocker ratio. There must be improvements in valve control to be had. Anything you care to share will be greatly appreciated.
Re: 514 on the dyno
[Re: AndyF]
#804190
09/20/10 02:40 PM
09/20/10 02:40 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
Cool beans I know it's been a long time in the making, block has been around for awhile etc...congrats!
Rich H.
Esse Quam Videri
