Mopar P4120068 rod bolt set? #804150
09/18/10 01:03 AM
09/18/10 01:03 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
Just bought a set of these and now I'm hearing that there are some failure reports. Dang! They will be going into a mostly stock 440 that will see 90% street duty and a little weekend racing...never above maybe 5000rpm. They must be at least a little better then stock bolts...no? Any comments?
Re: Mopar P4120068 rod bolt set? [Re: polkat] #804151
09/18/10 01:21 AM
09/18/10 01:21 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Suposedly...there was a bad batch of them many years ago.Almost 10 years ago at least.Can't say for sure.I think IMHO,that in your application they will be fine.
Nautilus Racing-
Re: Mopar P4120068 rod bolt set? [Re: polkat] #804152
09/18/10 01:22 AM
09/18/10 01:22 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i have used them with no problems at 6500 rpm
may times .
however i always look over the nuts very carefully with a magnifying glass as i did get one set once that had cracks lengthwise in the nuts , prob a problem with bad heat treating procses ?
Re: Mopar P4120068 rod bolt set? [Re: polkat] #804153
09/18/10 01:25 AM
09/18/10 01:25 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I've used them numerous times over the years, never had a problem ever, and I run the engines up to the valve float limiter many a times too...
I heard years ago of many ARP rod bolt failures, it makes me wonder where the stories come from to be truthful....
CrAzYMoPaRGuY
