tc weight removal?? #804142
09/18/10 12:13 AM
09/18/10 12:13 AM
wi
sixpaccornet Offline OP
wi
hi again mopar land.was told to knock the weights off torq convertor because of a bad vibration(85 318 in place of a 74 360) 727 trans.any suggestions on a simple way to get the weight off??i started drilling the spot weld but slow going thank six
Re: tc weight removal?? [Re: sixpaccornet] #804143
09/18/10 12:26 AM
09/18/10 12:26 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
4" grinder,,, be carefull
I am truckless..
Re: tc weight removal?? [Re: sixpaccornet] #804144
09/18/10 12:30 AM
09/18/10 12:30 AM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
You can use either an air or electric hand grinder with a cutoff disc.If you have a disc that is almost used up(small diameter) you will be able to work in the tight space.After you grind the small welds use a chisel or screw driver and it will pop off.Wear goggles or safety glasses!
