Need help positioning my motor... #803817
09/17/10 04:17 PM
09/17/10 04:17 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Since have not had a small block in an A body in a long time, and have nothing to compare it to, I need to find out where it should be centered/offset to the factory location.
There are no motor mounts, so I am using a motor plate. Could someone give me a measurement from either side (or better yet both) of the inner frame rail to the center of the crankshaft bolt? Looking for a measurement from a 67-76 A body. I thought the motor was offest because of the steering but can't remember. I am sure measurements may vary because not all came off the production line exactly. Or if you can take a measurement from a better reference point that woud be fine too, but seems that the frame to the bolt would be the easiest/most accurate.
Thanks in advance!
Brian
Re: Need help positioning my motor... [Re: Scamp451] #803818
09/17/10 06:15 PM
09/17/10 06:15 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Should be 2 1/2 inch off set. Measure from center of crank shaft to frame rail on each side, should see adjust too 2 1/2" to the passenger side. Roughly 5 1/4" from center of crankshaft to top of the K frame as far as height.
Re: Need help positioning my motor... [Re: Bob_Coomer] #803819
09/17/10 08:06 PM
09/17/10 08:06 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Wow, that seems like a lot Bob. Not arguing, just seems like a ton to take to the other side. The motor plate put the height right where you said it should be. I was able to get it over 2" so far, I can probably get another 1/2".
Re: Need help positioning my motor... [Re: Scamp451] #803820
09/17/10 08:11 PM
09/17/10 08:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
just bolt your headers on, they will tell you just about where it has to be
Re: Need help positioning my motor... [Re: Quicktree] #803821
09/17/10 08:16 PM
09/17/10 08:16 PM
Manassas, VA USA
Scamp451 Offline OP
Scamp451  Offline OP
Manassas, VA USA
Tried that Quick, but these were modified and had tues rolled so still not quite sure!
Re: Need help positioning my motor... [Re: Scamp451] #803822
09/17/10 08:40 PM
09/17/10 08:40 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I would defiantly have the headers on when locating any engine.....
If I didnt have the headers, I would wait till I had them.
Re: Need help positioning my motor... [Re: Scamp451] #803823
09/17/10 08:41 PM
09/17/10 08:41 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
The offset is 1 3/8".same as the rear
home of the
Sox and Martin Hemi Duster
Re: Need help positioning my motor... [Re: HEMIFRED] #803824
09/17/10 10:06 PM
09/17/10 10:06 PM
The further the motor is moved to the right side the more weight is on that side, same thing with the drivers position
Re: Need help positioning my motor... [Re: Cab_Burge] #803825
09/17/10 10:15 PM
09/17/10 10:15 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Just looked on TTI's web site, they have some dimensions
From there web site..
Factory Engine Location Specifications: K-members are not all identical and the dimensions must be checked to ensure proper fit. Check your engine location prior to installation of your TTI Headers. TTI Headers were designed to fit with the engines located to the factory specifications. If the engine is not located correctly in the chassis, the headers will not fit properly. If necessary, place shims between the insulator assembly and the K-frame mounting pad to achieve the proper dimensions. Shim kits and engine mounts can be purchased from Schumacher Creative Services of Seattle, WA (206) 364-7151.
and..
67-76 "A"-body / 66-74 "B"-body / 70-74 "E"-body applications: From the center of the crankshaft to the top of the K-frame, the correct distance is 5-1/4”. The engine is also offset towards the passenger-side. Measure from the center of the crankshaft to each frame rail. The difference should be 2-1/2”.
