motor plate vs std engine mount what's the good/bad? #803172
09/16/10 04:14 PM
09/16/10 04:14 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
I purchased a car that previously used motor plate for mounting and I was thinking of doing the same since the mounting for the std mounts were cut off the K frame. What is the good or bad with motor plate mounting? The pic is with the engine in the car I believe the mounts are from Jegs. I bought the car as a roller.
Re: motor plate vs std engine mount what's the good/bad? [Re: black64] #803173
09/16/10 04:44 PM
09/16/10 04:44 PM
Canada
Ghoste Offline
Ghoste  Offline
Canada
The good is that the engine is held rigidly in place and as much torque as possible is applied as quickly as possible to the rest of the drivetrain. The bad is that it puts a lot of twisting strain on a unibody.
I see a light at the end of the tunnel, and it's... ELECTROLUMINESCENT!
Re: motor plate vs std engine mount what's the good/bad? [Re: Ghoste] #803174
09/16/10 06:05 PM
09/16/10 06:05 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
I never ran the motor plates so I need all the input on them. I am trying not having to replace the K-frame.
Re: motor plate vs std engine mount what's the good/bad? [Re: black64] #803175
09/16/10 06:10 PM
09/16/10 06:10 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
With the plate, a fore and aft limiter is a good idea. The plate has a lot of strength left to right but will flex front to back.
Re: motor plate vs std engine mount what's the good/bad? [Re: forphorty] #803176
09/16/10 06:48 PM
09/16/10 06:48 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
Good info to think about.
