H wheel question(s) #803121
09/16/10 03:48 PM
09/16/10 03:48 PM
Baltimore, MD
moparbob71 Offline OP
Baltimore, MD
Hi Guys, I just picked up a set of 15x6 JJ wheels. 2 have big H's and one has a small H.
Here's the numbers-
#1-part # 2944169, shows March 1 date code, and a M5 with a 1 under it. Is this a 71 6 pack wheel?
#2-no part number,shows July 3 date code,6.0 rim size,M5 plant. Is this a 69 A12 wheel?
#3- part # 3560063, shows Nov. 2 date code and M5 plant. This is the one with the small H. What is this wheel? I have a few other small H wheels that I think came off a station wagon.
Thanks in advance for any and all info.
And thanks for the great site
Re: H wheel question(s) [Re: moparbob71] #803122
09/16/10 04:18 PM
09/16/10 04:18 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
#1-part # 2944169, shows March 1 date code, and a M5 with a 1 (1971) under it. Is this a 71 6 pack wheel? 15x6 was c-body ONLY in '71.
#2-no part number,shows July 3 date code,6.0 rim size,M5 What's under the M5? plant. Is this a 69 A12 wheel? The date sounds a little late.
#3- part # 3560063, shows Nov. 2 date code and M5 What's under the M5? plant. This is the one with the small H. What is this wheel? I have a few other small H wheels that I think came off a station wagon. mid-'70s B/C-body wheel
Re: H wheel question(s) [Re: 6bblgt] #803123
09/16/10 08:21 PM
09/16/10 08:21 PM
Baltimore, MD
Baltimore, MD
Hey thanks for the info Dan,so even though it has a 2944169 part number it's a C body?
On the other wheel I don't see a number under M5, I'm getting them soda blasted in a few weeks so maybe one will pop up.But there is a 7 on the left of the valve stem and a 3 on the other.
I'll repost once I get them cleaned up.
Thanks again, Bob
Re: H wheel question(s) [Re: moparbob71] #803124
09/16/10 09:09 PM
09/16/10 09:09 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Because of the wheel shape the M5/? often is not readable on the front of the wheel. Check inside the rim where "MADE IN CANADA" is stamped - there should be another M5/? stamping.
Re: H wheel question(s) [Re: 6bblgt] #803125
09/17/10 04:01 AM
09/17/10 04:01 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Not out of the question.
I can't afford this. mark
