Page 4 of 5 1 2 3 4 5
Re: Passon 5 Speed [Re: DaytonaTurbo] #802959
09/26/10 11:19 PM
09/26/10 11:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Basically because they're not building for muscle car guys. 6 speeds usually have two overdrive gears instead of one like a 5-sp. If the extra overdrive gear is just there to lessen the drop in rpm between 4th gear(1:1 ratio) and overdrive, I don't see the point. I could see this irritating some yuppie driving a lexus but it wouldn't matter to me.
You don't see the advantage of a 6 spd?,.....Dodge Viper for example, 6 spd double OD Tremec T56, with a 4:10 rear gear allows you awesome street performance and 190 MPH top end speeds;...that's the advantage of 6 spds....but you Mopar guys are just warming up to 5 spds,..finally ,....another 10 years you'll see the benefits of 6 gears
Re: Passon 5 Speed [Re: DAYCLONA] #802960
09/27/10 03:01 AM
09/27/10 03:01 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
And how many muscle car guys actually will drive their car like that to see any benefit from a 6-speed? 99% of your market for this just wants 4-sp gearing for the track and the street with a nice overdrive gear to make highway cruising comfortable.
Re: Passon 5 Speed [Re: DaytonaTurbo] #802961
09/27/10 04:18 AM
09/27/10 04:18 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Don't forget to mention, do you really want your driveshaft spinning at 8000+ rpm? Numerically lower gear rear end with a numerically higher low gear in the trans and a good overdrive keep the driveshaft spinning at something resembling a sane speed and still have a good launch.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Passon 5 Speed [Re: 67Charger] #802962
09/27/10 04:31 AM
09/27/10 04:31 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Hey I resemble that remark....
I view my driveshaft as a rev limiter. When I can't see out of the rear view mirror because it's vibrating so much, it's time to slow down.
Re: Passon 5 Speed [Re: DaytonaTurbo] #802963
09/27/10 09:40 AM
09/27/10 09:40 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
Having too much spread between 1:1 and overdrive is not always nice on the road. My Tremec (TKO-600, .64 overdrive) feels like a 6-speed missing the 5th gear. The minimum speed in 5th is the posted speed limit on public highways here, so I often have to switch back to 4th just to maintain RPMs above 1500 (worse things in life, I know).
And on a racetrack, I can't accelerate past 150mph because of the spread. 6500 RPM in 4th, all is fine, when I upshift the revs drop too much and I can only maintain that speed. There aren't too many tracks fast enough to require a good 5th ratio, I only know a couple here.
Had I known that, I'd have gone for the .80 final ratio version.
Re: Passon 5 Speed [Re: Keisler Sales] #802964
09/27/10 12:07 PM
09/27/10 12:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
All you need to install ours is Beer and band aids.
Good luck Jamie!!
You forgot the
Re: Passon 5 Speed [Re: roadrunninMark] #802965
09/27/10 01:04 PM
09/27/10 01:04 PM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
I can tell you that there is ZERO chance of fitting a 6 speed in one of these cars that can handle any kind of power without cutting the car up significantly more than the tremec kits require. Therefore, we are not into cutting, so this isn't an option for us.
As far as conversions. We can provide these parts as well. You have to compare apples to apples. You are talking about picking the phone up and ordering all the parts needed. There is an obvious convenience there. The other option is to scour the swap meets and boneyards (which are pretty well picked out by now) for the parts. Then make the necessary repairs to them and use them. Not everyone is up to this though.
The reverse harness will not be affected. we are using the same switch that the A-833 uses. Although it is in a different position, the factory harness is long enough.
As far as power handling ability. I am treading lightly here. I am not going to make outlandish claims. There are other units out there that have claimed over 1000 ft/lbs of torque. I am not here to bullsheet anyone. That just ain't gonna happen. The designs of those units and real world situations will not allow it. So, I will be more vocal on this once I am more comfortable. By all calculations we have at this point. It will be plenty stronger than a stock 18 spline A-833.
Thanks,
Jamie
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: Passon 5 Speed [Re: JamiePasson] #802966
09/27/10 01:17 PM
09/27/10 01:17 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Jamie,
Thanks for the continuing updates, but you still haven't told us A-body guys for certain whether there will be a transmission for our application, i.e. 1970 Dart. Come on, the suspense is killing me!
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Passon 5 Speed [Re: MadMatt] #802967
09/27/10 02:15 PM
09/27/10 02:15 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Matt,
Rest assured, There will be an A Body unit just for you guys. In fact, this is the first one to manufacturing. And everyone says A Bodies don't get any respect.
Jamie
Re: Passon 5 Speed [Re: JamiePasson] #802968
09/27/10 03:43 PM
09/27/10 03:43 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
At this point, .70:1 is final drive. I don't really want to comment on a weight estimate yet.
Just curious why .70? Seems like quite a deep drop to me.
I think .75 would be perfect.
I mean, with .75, you still have a 2.87 gearing w/a 4.10 rear end. Plenty high enuff if you ask me.
I don't think you'll get better efficiency and gas mileage w/RPMS less than 1500 RPMs cruise on the freeway.
Re: Passon 5 Speed [Re: 2fast4yourBrain] #802969
09/27/10 04:15 PM
09/27/10 04:15 PM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Ragtop,
This is where the numbers worked out to have virtually the same tailshaft rpm change between gears. I have had plenty of people balk at .75. We figure .70 is good overall.
Jamie
Re: Passon 5 Speed [Re: JamiePasson] #802970
09/27/10 04:39 PM
09/27/10 04:39 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Matt,
Jamie
THANK YOU!!
Re: Passon 5 Speed [Re: 67Charger] #802971
09/27/10 11:05 PM
09/27/10 11:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I had to read that twice but
Don't be the exception.
Re: Passon 5 Speed [Re: Supercuda] #802972
09/28/10 10:47 AM
09/28/10 10:47 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
that's what I like about the Richmond 5 speeed approach-- real deep first, and 1:1 5th, couple it with a 2.76 or 2.45 rear, you get a stronger ring gear, coupled with a low driveshaft speed.
want to know why the crown vic police interceptors are electronically limited to under 130 MPH? driveshaft speed.
2017 Grand Cherokee Overland
Re: Passon 5 Speed [Re: patrick] #802973
09/28/10 10:52 AM
09/28/10 10:52 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Another benefit of running 1:1 in fifth is that the shafts are all locked together (no gear mesh is in use) so gear wear is reduced and spin losses are minimized.
The flip side of getting a deeper first gear is that one of the gears has to get smaller (reducing torque capacity) or the gearbox has to get bigger to maintain gear sizes.
It's all a tradeoff.
Re: Passon 5 Speed [Re: JamiePasson] #802974
09/28/10 10:59 AM
09/28/10 10:59 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Ragtop,
Jamie
.75 isn't quite enough OD...IMHO...~.7 is about the best compromise. look at some of the more typical auto and manual OD's out there, they're all in that range (A500/518--.69, A833OD--.73, 700R4/4L60E--.73, etc)...
4.10's with a .7 is an effective 2.87 rear gear, .75 it's 308's....
so, with a 28" tall tire, 75mph (typical freeway speed in MI) would be 3700 RPM in 1:1, 2900 with a gear vendor's .78, 2800 with .75, 2600 with a .7, or 2400 with a TKO's .64....
for this combo, personally I like the .7 or .64....if it's still cranking along at near 3000 RPM at 75mph, like it would with a gear vendors or a .75, it doesn't seem worth it.
now, if the gears had been designed such that you had say, a 3.3 first, then .75 would be a nice OD to couple with a 3.55, and still have the first gear multiplication of a 4.10 with a 2.85 first, but a reduction in driveshaft speed....
Re: Passon 5 Speed [Re: JamiePasson] #802975
09/28/10 10:18 PM
09/28/10 10:18 PM
East Bay Area
Bladeruner69 Offline
East Bay Area
Sounds like it is just a matter of when they will be available. I will be waiting.
Re: Passon 5 Speed [Re: Bladeruner69] #802976
09/29/10 01:31 AM
09/29/10 01:31 AM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
I just hope it's not vaporware like the repop '71 'Cuda grille.
And...repop rear e-body door panels.
Re: Passon 5 Speed [Re: 2fast4yourBrain] #802977
09/29/10 02:04 AM
09/29/10 02:04 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Not to derail the topic of Jamie's excellent 5 speed trans thread but....
In fairness to Mike he was simply posting in an effort to do a feasability study on the 71 Cuda grilles by getting a feel for demand and feedback from potential customers, I don't recall him making any delivery promises or saying he had any plans to go into production, did I miss something?
Carry on..
Re: Passon 5 Speed [Re: ScottSmith_Harms] #802978
09/29/10 09:21 AM
09/29/10 09:21 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
Scott,
Not to derail the thread, but you did a good job derailing the thread!
I am just teasing you.
I know what is involved with making stuff as I am sure that many others out there know as well. Making driveline stuff is even more difficult than trim pieces that just need to sit there and look pretty. I am not taking away from those pieces by any means. I certainly have no intention of this item being vaporware. We have a tremendous investment thusfar on this project. I plan on seeing it throught.
Jamie
