Page 3 of 5 1 2 3 4 5
Re: Passon 5 Speed [Re: DaytonaTurbo] #802939
09/24/10 09:34 AM
09/24/10 09:34 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The m/t specific stuff is not cheap. You're looking a few hundred bucks for a used bell housing if you want a big block unit and/or a blow-proof unit. Few hundred for a decent clutch, couple hundred for a clutch pedal setup, then the linkage, shifter, blah blah blah it goes on and on. I'm in the process of a auto->4sp conversion and the $$ add up fast on this stuff and I've been scrounging for used parts.
I dunno about that, I converted my 87 Diplomat over to stick. The total to switch was under $1000. Ebay and bone yard shopping plus me doing all the work kept it real low. $125 for the trans, Ebay kit to rebuild it, Ebay clutch kit for $100, bone yard for clutch pedal/linkage/floor hump. MP kit to freshen up the linkages, boneyard flywheel out of a V6 Dakota, new Hurst shifter from Summit, bone yard for a drive shaft yoke, new u joints.
I started with nothing for a stick conversion, spent less than $1000 and had a 4 speed with all new or rebuilt (mostly by me) parts in it.
After I got done with the swap I found a package deal on 2.5 A833's, a couple of bells, a big box full of linkages, pedals, clutch stuff, etc for under $300, on Ebay, for my 65 Cuda.
Don't be the exception.
Re: Passon 5 Speed [Re: Supercuda] #802940
09/24/10 10:27 AM
09/24/10 10:27 AM
Tennessee
Keisler Sales Offline
Tennessee
You obviously haven't checked out parts for the more popular cars IE: 66-70 B and 70-70 E and 71-74 B cars. Brewers does a complete 4 speed swap for The mid 4k range. Our pricing to do a FORD trans not Gm trans into most of the popular Mopars is around $5300 including hydraulic it actually doesn't save money to go mechanical because all the parts involved.
We have a very complete kit right down to every nut bolt ans washer even the factory boots and trim rings. All you need to install ours is Beer and band aids.
Good luck Jamie!!
Keisler Engineering www.keislerauto.com
#1 Choice of Overdrive Transmissions with Over 14,000 Sold
Re: Passon 5 Speed [Re: Keisler Sales] #802941
09/24/10 10:36 AM
09/24/10 10:36 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Being quite familiar with Kieslers offerings and prices I can second what Gene said above, those are accurate numbers. That being said, I'll be first in line to try a new Passon 5 speed basically because it sounds like it will be a simpler swap, will not require cutting or modifying my car and is more like the factory unit it replaces. It looks like price will make it easier to afford as well. I guess we'll all have to wait and see, get to work Jamie!
Re: Passon 5 Speed [Re: Keisler Sales] #802942
09/24/10 02:32 PM
09/24/10 02:32 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Apples to oranges my friend. Just try finding junkyard parts for any of the popular muscle era cars. Not gonna happen. I scrounged for used stuff and the cost still adds up. There are no cheap big block bellhousings and no $100 new ebay clutch will hold up behind a strong 440 for a run down the track. I can convert an 80's fwd turbo mopar from auto to stick for a couple hundred bucks including the price of a new clutch. Can't even compare the two.
Re: Passon 5 Speed [Re: DaytonaTurbo] #802943
09/24/10 02:53 PM
09/24/10 02:53 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Wow, I just stumbled on this thread. How exciting! Now I am glad I didn't spring for the 4 speed OD a couple years ago!
Re: Passon 5 Speed [Re: jbc426] #802944
09/24/10 03:58 PM
09/24/10 03:58 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
.....600 lb/ft of torque should not be a problem at all.
600 lb/ft? I was hoping it would handle somewhere in the 700lb/ft range. I've got 680b/ft with a relatively mild, hydraulicly cammed 493 inch motor. Do you think that your new transmission will handle it ok?
Perhaps a better question is at 600ft lb/ft; relatively speaking, does that make the new 5 speed unit stronger than an 18 spline or are they about the same?
Re: Passon 5 Speed [Re: jbc426] #802945
09/24/10 10:16 PM
09/24/10 10:16 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Great Job , Keep plugging ,
too bad the post got jacked for a second .
Ok . Ill stop ..
Can I trade in and upgrade from my "NEVER INSTALLED YET BECAUSE I KEEP GETTING DISTRACTED By other car projects " passon 4 speed OD ?
Im almost there ..BUT, I think Im getting distracted from my road car again .
Re: Passon 5 Speed [Re: sogtx] #802946
09/24/10 11:14 PM
09/24/10 11:14 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Will there be a bolt in A body 5spd too?
Re: Passon 5 Speed [Re: NV69B7RR] #802947
09/25/10 04:33 AM
09/25/10 04:33 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Inquring on A body fittment too!
Re: Passon 5 Speed [Re: gdonovan] #802948
09/25/10 01:48 PM
09/25/10 01:48 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
I'd like to confirm that too. Will the A-bodies be covered as soon as you bring the trans to market?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Passon 5 Speed [Re: MadMatt] #802949
09/25/10 03:15 PM
09/25/10 03:15 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I'd be interested in the A-body one too...the four-speed is nice in my Dart but another gear would be sweet.
As for the cost of the swap, we've got $1,500 in ours...using lots of used parts and we rebuilt the A833 ourselves. The heavy duty clutch/pressure plate and flywheel were the most expensive parts. It does nickle and dime you.
Re: Passon 5 Speed [Re: dustergirl340] #802950
09/25/10 06:04 PM
09/25/10 06:04 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
If this swap is as easy as removing my 18 spline box and installing your 18 spline 5 speed box, count me in. Will the speedo cable, trans crossmember mount, and reverse light switch wiring needs any mods? Will the trans length be the same so that no drive shaft mods are needed? I absolutely refuse to modify any part of my stock floor pan to accomodate a swap of this type. This would be going into my 68 Charger, 426 Hemi with stock exhaust. If all I have to do is purchase the trans and some fluid it seems like it may be a no brainer. Sounds like the sooner you get all the engineering and testing done the sooner the market will be flooded with 18 spline 4 speed hemi boxes.
Re: Passon 5 Speed [Re: badblack68] #802951
09/25/10 06:24 PM
09/25/10 06:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
100%
BTW, mark me down for 2 A body units!
Re: Passon 5 Speed [Re: JamiePasson] #802952
09/25/10 07:26 PM
09/25/10 07:26 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Same ratios as street trans plus od.
Far removed from red stripe spread.
Can understand the marketing to larger group of potential buyers (street) vs (race).
Personally, Id just bolt on a gear vendors unit if I was so desperate for od, cheaper by a couple of grand.
Modifying sheetmetal not a concern here.
Sounds interesting tho and they will sell.
Good luck.
Re: Passon 5 Speed [Re: theclutcher] #802953
09/25/10 10:25 PM
09/25/10 10:25 PM
GA
roadrunninMark Offline
GA
Whats the chance of shelving the 5 speed idea and switching right to making it a 6 speed? hmmmmmmm.........
Re: Passon 5 Speed [Re: roadrunninMark] #802954
09/26/10 04:37 PM
09/26/10 04:37 PM
SE Pa.
LimeliteAero Offline
SE Pa.
whats the gain?
Re: Passon 5 Speed [Re: LimeliteAero] #802955
09/26/10 04:52 PM
09/26/10 04:52 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
whats the gain?
More costly to built and buy.
Hey 6 is better that 5, right?
Seriously, I'm sure there is some little amount of fuel economy to be gained from an extra gear, but I don't see that justifing the extra cost and possibly/probably tighter fitment.
Re: Passon 5 Speed [Re: autoxcuda] #802956
09/26/10 05:30 PM
09/26/10 05:30 PM
GA
GA
tighter gear ratios, more versatility... lot of car companies are going with 6 speed manuals / 7 speed automatics. Must be something to it. Definitely somewhat more complicated/ expensive...
Re: Passon 5 Speed [Re: roadrunninMark] #802957
09/26/10 09:35 PM
09/26/10 09:35 PM
Manitoba, Canada
Manitoba, Canada
Basically because they're not building for muscle car guys. 6 speeds usually have two overdrive gears instead of one like a 5-sp. If the extra overdrive gear is just there to lessen the drop in rpm between 4th gear(1:1 ratio) and overdrive, I don't see the point. I could see this irritating some yuppie driving a lexus but it wouldn't matter to me.
Re: Passon 5 Speed [Re: sogtx] #802958
09/26/10 10:33 PM
09/26/10 10:33 PM
Texas
shart70rt Offline
shart70rt  Offline
Texas
Same situation for me, new gears are in the tranny, but the new tranny's will probably be ready before I have the Charger back together again.
70 Go Mango Charger RT
White Vinyl Top
18 Spline 4 speed
Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing
505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
